[off topic] Closing Dos Batch File Windows
Troy, Try entering a line with the word "exit" in it. That should close out
the window..
Lyal Shoff
Processor/MIS
Hanard Machine Inc.
859 7th St. NW.
Salem, Oregon 97304
Phone: 503-364-3952
Fax: 503-364-6895
Does anyone know how to make a DOS batch file that automatically closes the DOS window after it is done? Is there a DOS command to do this?
Troy Funte
Liberty Electronics
On Windows 95 and 98 machines. When you first run a DOS application on that
computer it creates a PIF file (in your Windows\PIF directory). If you open
the PIF file properties, there is a check box for "close on exit". I don't
know the reason but the default is unchecked, thus leaving the DOS window
open. Check it and the window will close when the DOS app ends.
Michael Podlin
Sent: Sunday, March 11, 2001 6:48 PM
To: Vantage
Subject: [Vantage] [off topic] Closing Dos Batch File Windows
Troy Funte
Liberty Electronics
"exit"
Is this a batch file? I have found if a launch a CMD or BAT file, they close
when they are done even if I don't put in an EXIT command. If it is a batch
file, check to make sure the last command is actually finishing by putting a
PAUSE command after the last line. If the batch file stops to wait for a key
press, then at least you know the previous command is finishing.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
Try putting EXIT as the last line of the batch file (or the last line to be
executed)
Jim S.
Sent: Sunday, March 11, 2001 7:48 PM
To: Vantage
Troy Funte
Liberty Electronics
Yahoo! Groups Sponsor
Click Here to Find Software Faster
Exit didn't close the window on the batch file until I selected Properties on the DOS box and checked "Close on Exit". Now it closes fine.
Thanks for the help Mike, Brian, and Jim
Troy Funte
Liberty Electronics
----- Original Message -----
To: Vantage
Troy Funte
Liberty Electronics
