Everything I have looked at cost more than it was worth. All the PCs in the
shop are now disposable, in part or whole. If it takes more than 10 minutes
to clean a mouse or keyboard it is cheaper to buy a new one. I am however
going to try an optical (ball-less) mouse and see if the extended life
justifies the cost. Our shop is relatively free of airborne crud (oil,
dust, metal chips) so replacing components (video card, power supply, etc..)
if they fail (a big if) is often cheaper than prevention. The typical PC
costs $350 (home-made, plus a little labor) plus a monitor ($120) and the
most expensive PC component is $80 (the motherboard or the CPU) so life
extension is mainly just a good surge protector. The #1 (and only so far)
cause of failure has been a forklift running over the table it was on. With
a three year lifetime a $500 PC costs about $166 a year and if the chances
of failure are about 1 in 4 the risk adjusted cost (expected loss) is about
$40/yr. So any preventative measures should not cost more than that per
year. For us anyway... your milage may vary.
-Todd
Sent: Thursday, September 14, 2000 4:31 PM
To: vantage@egroups.com
Subject: [Vantage] Off Topic-Dirty Shop environment
<http://click.egroups.com/1/8930/13/_/411782/_/968966960/>
<http://adimg.egroups.com/img/8930/13/_/411782/_/968966960/funfreasyBuis468x
60.gif>
<http://www.egroups.com/> eGroups My
<http://www.egroups.com/mygroups> Groups | vantage Main
<http://www.egroups.com/group/vantage> Page | Start a new
<http://click.egroups.com/1/8150/13/_/411782/_/968966960/> group!
What have others used to extend the life of computers/keyboards in dirty
shop environments? Are you satisfied?
<http://www.egroups.com/files/vantage/>
-Todd
60.gif>
