Off Topic-DOS command question
DOS applications create a PIF file in your C:\Windows\PIF directory. If you
go there, right click on it and select properties, there is a check-box for
close on exit. By default, this is always unchecked. Check it, save it,
and your problems should be solved.
Sent: Friday, January 18, 2002 5:18 AM
Subject: [Vantage] Off Topic-DOS command question
Ya'll:
I can't for the life of me remember the command to close the window after a
DOS .bat file runs. I've tried CLOSE and EXIT but the window remains open.
If it is one of those commands, could the problem be because I'm running the
.bat file by using Windows STARTUP feature?
TIA......
Rick Gors
MR/MMIS
Osco
Ya'll:
I can't for the life of me remember the command to close the window after a DOS .bat file runs. I've tried CLOSE and EXIT but the window remains open. If it is one of those commands, could the problem be because I'm running the .bat file by using Windows STARTUP feature?
TIA......
Rick Gors
MR/MMIS
Osco
Rick,
Best way I've found to do it is make an MS-DOS shortcut to the .bat file.
Then go into the shortcut properties and under the Program tab is a checkbox
for "Close on Exit". Drag the shortcut it into the startup folder (or
create it there) and if the planets and stars are aligned correctly it
should work.
Rick
