Off Topic - Drive Configuration
4 gigs if you can, 2 billion bytes these days is nothing.
We have about 5 solidworks stations waiting for a reformat because the 2gig
partition is filling up with temp files... Had we used 3 or 4 gigs for our
primary partition originally, we'd have saved significantly more than
$.02...
Thaddeus
Sent: Tuesday, December 18, 2001 9:20 AM
Subject: RE: [Vantage] Off Topic - Server Drive Configuration
I would leave at least 3gb in your first partition for OS, I have some NT
systems that are pushing hard against the 2GB partitions.
I don't think this is even .02 worth.
Lydia
Sent: Tuesday, December 18, 2001 7:47 AM
To: 'vantage@yahoogroups.com'
I spend some time on this issue with Progress support about 6 months ago.
They suggests two logical drives. One for your boot partition. The raid
level should be 1 using 2 physical drives. The second logical drive should
be RAID 10 using 4 physical drives. After I made the change to RAID 10 I
seen a huge speed increase. If you don't have a raid card you should invest
in one. Windows still uses allot of overhead to maintain software raid.
Jeremy
