[Off Topic] Event Viewer Error/Warning
--- In vantage@yahoogroups.com, "Dina Hieber" <dhieber@v...> wrote:
> "DHCP received an unknown option 026 of length 002. the raw
option
> data is given below."
see if this helps anyone in your networking dept:
[excerpt from rfc1533 @ http://www.cis.ohio-state.edu/cgi-
bin/rfc/rfc1533.html]
(DHCP Protocol)
5.1 Interface MTU Option
This option specifies the MTU to use on this interface. The MTU is
specified as a
16-bit unsigned integer. The minimum legal value for the MTU is 68.
The code for this option is 26, and its length is 2.
Code Len MTU
| 26 | 2 | m1 | m2 |
[excerpt from comer, internetworking with tcp/ip]
MTU = Maximum Transfer Unit -- the maximum size a physical packet
can be in a given
network before it is fragmented.
i have no idea other than it MAY have something to do with
the packet size of a DHCP message possibly exceeding the MTU
of the network (or intermediate subnet).
-or-
the DHCP version (?) doesn't understand option 26 (it doesn't
follow RFC 1533).
hopefully that info might trigger a thought with a techie
somewhere...
...my answer is probably worse than the problem :-(
Mark Fostervold
Systems Analyst / DB Admin
BAE SYSTEMS Precision Aerostructures
Wellington, KS
Vantage 5.2.305 (not live yet)
Hello Everyone,
I have a windows NT workstation connected to a Windows 2000 Server. I
am receiving the following error/warning on a workstation in their event
viewer.
"DHCP received an unknown option 026 of length 002. the raw option
My ip addresses are DHCP not static. I did a search on google for this
message and I did not see anything.
Has anyone else see this or know where I can find what is causing this.
Best Regards,
Dina Hieber
Vamco International, Inc.
(412) 963-7100 Phone
(412) 963-9511 Fax
http://support.microsoft.com/default.aspx?scid=kb;en-us;181024
Try that link,
I'm not sure if its your exact problem; although, its pretty close.
Article ID: 181024
Jessee Holmes
Stremel Manufacturing Company
Sent: Monday, January 27, 2003 1:52 PM
Subject: [Vantage] [Off Topic] Event Viewer Error/Warning
Hello Everyone,
viewer.
Best Regards,
Dina Hieber
(412) 963-9511 Fax
