(off topic) - Excel question
Brian,
Thankyou, that worked a treat.
Anton
--- In vantage@y..., Brian Boyes <brianb@p...> wrote:
> Excel may think that there is something in a cell out at the end of
the
> spreadsheet, so it won't let you insert any more. To check, press
Ctrl+End.
> This will jump you to what Excel *thinks* is the last cell. Its
probably in
> column IV.
> Anyway, to fix your problem, select the first empty column in you
sheet and
> select all the way to column IV, then delete (not clear) the
columns. That
> will fix the problem.
> Brian Boyes,
> Systems Administrator,
> Precision Resource Canada Ltd.
> <http://www.precisionresource.com>
> <mailto:brianb@p...>
> > -----Original Message-----
> > We have an old spreadsheet that we can't add any more columns to.
> > Which seems strange, as there are only about 40 columns in use on
it.
> > If I try to add a column, I get an error message - "Cannot
> > shift non-blank
> > cells off the worksheet"..
Which seems strange, as there are only about 40 columns in use on it.
If I try to add a column, I get an error message - "Cannot shift non-blank
Has anyone come across this before? I presume there is some setting in the
sheet that is causing this.
Thanks for any help.
Anton Wilson,
Systems Analyst,
Deanestor Ltd
Anton,
I had a problam almost like that. I just copied the
spread sheet and pasted into a new spread sheet and
that worked.
Pete
> more columns to.
> Anton Wilson,
> Systems Analyst,
> Deanestor Ltd
> removed]
__________________________________________________
Terrorist Attacks on U.S. - How can you help?
Donate cash, emergency relief information
http://dailynews.yahoo.com/fc/US/Emergency_Information/
Excel may think that there is something in a cell out at the end of the
spreadsheet, so it won't let you insert any more. To check, press Ctrl+End.
This will jump you to what Excel *thinks* is the last cell. Its probably in
column IV.
Anyway, to fix your problem, select the first empty column in you sheet and
select all the way to column IV, then delete (not clear) the columns. That
Brian Boyes,
<mailto:brianb@...>
> shift non-blank
