Off Topic ISA Server
--- In vantage@y..., "pile_of_34" <peter.paasch@a...> wrote:
> Check your access policy. Make sure HTTP and HTTPS is open, and IP
> Packet filter needs to be set to allow HTTP. Also check your
routing policy under network config.
> --- In vantage@y..., "Heisey, Lois" <lheisey@m...> wrote:
> > Thanks Todd but no that is not it. I know all appropriate IP
> addresses.
> > Mail is coming in and going out fine. It appears to be
> specifically a
> > problem with port 80. I can not telnet to it so there must be
> something
> > specific in that area. Any more ideas?
> > -----Original Message-----
> > From: Todd Caughey [mailto:caugheyt@h...]
> > Sent: Thursday, May 02, 2002 10:51 AM
> > To: 'vantage@y...'
> > Subject: RE: [Vantage] Off Topic ISA Server
> > Don't know if it is the same situation for you but I had a
similar
> problem
> > when I had to replace our SonicWall firewall. I found the router
> (on the
> > T1) had its own IP address in addtion to the external side
address
> on the
> > firewall. Once I got each one right the inward access (like
email
> messages)
> > could get in. Way back when I had setup the SonicWall the first
> time I had
> > not recorded which IP address went where so I had to reinvent the
> solution
> > by trial and error.
> > -Todd C.
> > From: lheisey3 [mailto:lheisey@m...]
> > Sent: Thursday, May 02, 2002 9:59 AM
> > To: vantage@y...
> > Subject: [Vantage] Off Topic ISA Server
> > Does anyone use an ISA server for firewall? My drive failed and
I
> > replaced and rebuilt it last night. Mail, terminal services work
> > great. However, noone can get on the net. I have been through
my
> > config 5 times and can't see the problem. I can ping outside of
> > work. From outside I cannot ping the external address of the
ISA.
> > Any help would be great.
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17
> 050071
> > 83:HM/A=1000239/R=0/*http://ads.x10.com/?
> bHlhaG9vaG0xLmRhd=1020351574%3eM=22
6014.2032696.3508022.1829184/D=egroupweb/S=1705007183:HM/A=1000239/R=1
> > <http://us.adserver.yahoo.com/l?
> M=226014.2032696.3508022.1829184/D=egroupmai
> > l/S=1705007183:HM/A=1000239/rand=743939055>
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
> > already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/.>
> > http://groups.yahoo.com/group/vantage/messages
> > <http://groups.yahoo.com/group/vantage/messages>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > <http://groups.yahoo.com/group/vantage/links>
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> > <http://docs.yahoo.com/info/terms/> .
> must have
access. )
> Builder and
Does anyone use an ISA server for firewall? My drive failed and I
great. However, noone can get on the net. I have been through my
work. From outside I cannot ping the external address of the ISA.
Don't know if it is the same situation for you but I had a similar problem
when I had to replace our SonicWall firewall. I found the router (on the
T1) had its own IP address in addtion to the external side address on the
firewall. Once I got each one right the inward access (like email messages)
could get in. Way back when I had setup the SonicWall the first time I had
not recorded which IP address went where so I had to reinvent the solution
by trial and error.
-Todd C.
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1020351574%3eM=22
6014.2032696.3508022.1829184/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014.2032696.3508022.1829184/D=egroupmai
Thanks Todd but no that is not it. I know all appropriate IP addresses.
Mail is coming in and going out fine. It appears to be specifically a
problem with port 80. I can not telnet to it so there must be something
To: 'vantage@yahoogroups.com'
by trial and error.
-Todd C.
ADVERTISEMENT
What is your public subnet? Make sure the router and IP address of
the external card are on the same subnet. If you use NAT then check
your Router Config. Then Ping the routers Public IP address. If you
don't know it your ISP will, or it is usually the second available IP
in your address block. If your router responds then it may not be
passing the info to the ISA server. I doubt it is a problem with
ISA, but their are so many config options it is difficult with out
more info.
addresses.
specifically a
something
> To: 'vantage@y...'
problem
(on the
on the
messages)
time I had
solution
> by trial and error.
> -Todd C.
> To: vantage@y...
> ADVERTISEMENT
050071
must have
Builder and
must have
Builder and
Thanks... however I should have been more specific. The port would be
available for about 20 minutes then the ISA server would need to be rebooted
once the port was no longer available. The same applied to port 25.
Sent: Tuesday, May 14, 2002 2:03 PM
Subject: [Vantage] Re: Off Topic ISA Server
addresses.
specifically a
something
> To: 'vantage@y...'
problem
(on the
on the
messages)
time I had
solution
> by trial and error.
> -Todd C.
> To: vantage@y...
> ADVERTISEMENT
050071
must have
Builder and
must have
Builder and
Where is IP packet filter? Do you mean in ISA mgmt? I don't have IP packet
filter.
addresses.
specifically a
something
> To: 'vantage@y...'
problem
(on the
on the
messages)
time I had
solution
> by trial and error.
> -Todd C.
> To: vantage@y...
> ADVERTISEMENT
050071
must have
Builder and
must have
Builder and
