Wend:
After setting up a printer on a print server, you can monitor the print
server (and consequently the printer). The HP print server can actually
be observed using a browser like netscape by plugging in the TCP address
(XXX.XXX.XXX.XXX) from anywhere on your network. You cannot "monitor" a
printer otherwise.
Ri
MIS
Osco
printer otherwise.
Ri
MIS
Osco
> Someone mentioned the other day about free shareware for HP WebJet
> Admin. Is this only usable under JetDirect print server? I only have
> 1 printer under this print server so I was looking to monitor my other
> printers as well that are not under a print server.
> Wendy Pursche
> Network Administrator
> Schmald Tool & Die, Inc.
> (810) 743-1600 ext.323
> wpursche@...
> eGroups Sponsor
> We no longer allow attachments to files. To access/share Report
> Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it,
> go to www.egroups.com, login and be sure to save your password, choose
> My Groups, choose Vantage, then choose Files. If you save the
> password, the link above will work the next time you try it.)
