Off topic
One more thought I just got from a friend...
He said just Alt-Esc or just Ctrl-Esc. He found some that he was unable to
get to unless he created a keyboard error during the boot (unplugging it
works sometimes) and then chose to enter the setup from there. Again, good
luck.
Aaron Hoyt
System Administrator
Design Standards Corp.
PO Box 1620
Charlestown, NH 03603
Tel 603-826-7744
<mailto:Aaron@...>
Sent: Tuesday, October 03, 2000 10:38 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Off topic.
I have tried all of the key sequences with no success.
Eric Tolliver
IT\MIS
Continental Industries Inc.
5456 E. Mcdowell Rd.
Mesa, Az 85215
http://ciirelays.com/
mailto:e.tolliver@...
Sent: Tuesday, October 03, 2000 5:00 AM
I came into the job I am in from a hardware repair background so I actually
feel like I might have something to offer for a change...
Be aware that many of the older Acer computers REQUIRE a cold boot to get to
the bios. I can't remember any other key sequences for Acer than are
listed, but I do remember many of them did have that Cold Boot issue. Good
luck.
How old is the Acer? Many years ago they used the Ctrl-Alt-Esc key sequence
during the memory check to enter the BIOS. I think there may have been a
period when they used the Ctrl-S sequence as well before finally adopting
the standard Del key. Give each of these a shot during the memory test on
startup and see if you get lucky.
Regards,
John.
Has anyone been able to get into a Acer computer�s BIOS to change the hard
drive size that it thinks is in there.
Eric Tolliver
IT\MIS
Mesa, Az 85215
Regards,
John.
Sent: Monday, October 02, 2000 3:52 PM
To: 'Vantage
Subject: [Vantage] Off topic.
Has anyone been able to get into a Acer computer's BIOS to change the hard
Eric Tolliver
IT\MIS
Mesa, Az 85215
If you are referring a Settings change we got round this problem by
attaching the base unit to a screen which was working fine else where.
This allowed us access to the settings screen in order to reset them.
When we plugged the original screen back in, the settings were fine
again.
Hope this is what you were looking for
Sophie
Sent: Monday, October 02, 2000 9:52 PM
To: 'Vantage
change the hard
Eric Tolliver
IT\MIS
Mesa, Az 85215
-------------------------- eGroups Sponsor
Files, please go to the following link:
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
password, the link above will work the next time you try it.)
luck.
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
<mailto:Aaron@...>
Sent: Monday, October 02, 2000 5:00 PM
To: 'vantage@egroups.com'
Regards,
John.
To: 'Vantage
Eric Tolliver
IT\MIS
Mesa, Az 85215
Eric Tolliver
IT\MIS
Mesa, Az 85215
luck.
Regards,
John.
I had an old (ancient) Gateway once that you had to press CNTL + ALT + S
at the C:\ prompt not during the memory sequence. Did that ever take
some time to figure out.
Juliet Martin
Rosenboom Machine & Tool, Inc.
1530 Western Avenue
Sheldon, IA 51201
712-324-4854
www.rosenboom.com
jmartin@...
Eric Tolliver
IT\MIS
Mesa, Az 85215
