[off topic]
no temp 48.50 bob http://www.panache-yes.com/mileagerate.html
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, September 26, 2005 9:58 AM
Subject: RE: [Vantage] [off topic]
> IRS standard mileage rate? $0.405 per mile
> http://www.irs.gov/newsroom/article/0,,id=131232,00.html
> -----Original Message-----
Of
> dhieber
> Sent: Monday, September 26, 2005 9:54 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] [off topic]
> Does anyone know where I can find the national price to reimburse an
> employee for gas. I thought I Had it bookmarked but I can't find it
> anywhere.
> Thanks
> Have a Nice Day,
> Dina Hieber
> Vamco International, Inc.
> Phone (412) 963-7100
> Fax; (412) 963-7160
> www.vamcointernational.com
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
> Yahoo! Groups Links
Anyone seen this error after installing Office 97 Professional and first starting Access?
"Microsoft Access can't start because there is no license for it on this machine."
We are using the Same CD and license number that we always do for our corporate license agreement. It's happened on two different PC's now for the same user.
Any ideas what's going on?
Troy Funte
Liberty Electronics
Could it be you're using an upgrade disk, and there is no existing Office
products on the unit? - Les
> From: Troy Funte [SMTP:tfunte@...]
> Sent: Tuesday, January 15, 2002 1:26 PM
> starting Access?
> machine."
> the same user.
> Troy Funte
> Liberty Electronics
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
It's a full version CD, and the install goes fine. When you open Access the first time, the error comes up.
Troy Funte
Sent: Tuesday, January 15, 2002 7:41 AM
> starting Access?
> machine."
> the same user.
> Troy Funte
> Liberty Electronics
Yahoo! Groups Sponsor
ADVERTISEMENT
>starting Access?
>machine."
Yeah, I ran into that once, but can't remember the details of the
fix. It's some kind of conflict with other MS software (even stuff that's
since been uninstalled.) Try punching the error message into google.com -
I found some solution or patch utility pretty easily when it happened here.
-Wayne
this machine."
> Troy Funte
> Liberty Electronics
Check the Microsoft knowledge base for Article Q141373.
It mentions a tool for windows 98 as well as some other possible fixes
Matt
Sorry, my previous reply doesn't seem to have posted correctly...
Is it possible that you're installing on machines that already have,
or had, Office 2000 installed?
Denise Brown
this machine."
> Troy Funte
> Liberty Electronics
Had Office previously been installed on this machine (what OS is it?)
MS has a utility called "Office 97 File and Registry Eraser Utility"...
Q) I'm receiving the error message "Microsoft Access can't start because
there is no license for it on this machine." I've tried re-installing but
it doesn't solve the problem. How can I fix this?
(A) Most of the times, this error message comes up when Access did not
register properly during the install process.
As a part of the setup, the following entries are created in the
registry.
(For Access 97):
\\HKEY_CLASSES_ROOT\Licenses\8CC49940-3146-11CF-97A1-00AA00424A9F
If the entries are not present or are corrupted, this error message will
come up.
To fix the problem, re-run the setup with a /y switch.
Setup /y
Under Windows 98, this problem can come up due to the installation of
Microsoft Publisher 97. For details, check out the knowledge base article
and download the tool.
also see: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q141373
Regards, Lee
starting Access?
machine."
the same user.
Troy Funte
Liberty Electronics
This happened on both Windows XP machine. Previously Word 2000 (from Microsoft Works being preinstalled) was on the machine.
Troy
Sent: Tuesday, January 15, 2002 8:11 AM
registry.
(For Access 97):
come up.
Setup /y
Regards, Lee
starting Access?
machine."
the same user.
Troy Funte
Liberty Electronics
ADVERTISEMENT
Hmmm. If I were a gambling man, I'd bet you're already uninstalling Word
2000. Cause ya know XP isn't the problem. : ) Les
> Sent: Tuesday, January 15, 2002 2:25 PM
> Subject: Re: [Vantage] [off topic]
> Troy
> From: Lee Ingalls
> because
> but
> not
> registry.
> (For Access 97):
> come up.
> Setup /y
> of
> article
> also see:
> Regards, Lee
> From: Troy Funte [mailto:tfunte@...]
> starting Access?
> machine."
> for
> the same user.
> Troy Funte
> Liberty Electronics
> ADVERTISEMENT
FIXED.
Michael's bizzarre fix (renaming the hatten.ttf font) worked, and Matt's
Q-Base Article explained why. I won't try to explain here. THANKS
EVERYBODY! Now on with the work of the day.
Troy Funte
Liberty Electronics
Thanks.
To: <tfunte@...>
Sent: Tuesday, January 15, 2002 7:39 AM
> Troy,
> I had the same problem a few months ago and this corrected my problem. It
> doesn't make sense, but it works.
> Michael
> Quit all Microsoft Office programs that may be running on your computer.
> On the Start menu, point to Find , and then click Files or Folders .
> In the Named box, type hatten.ttf .
> In the Look in box, type c:\windows\fonts .
> NOTE : The path to the Fonts folder may be different on your computer.
> Click Find Now to start the search.
> NOTE : If Hatten.ttf is not found, try searching for Haettenschweiler.ttf.
> Haettenschweiler is the full name of the Hatten font.
> Under Name , right-click the hatten.ttf file, and then click Rename on the
> shortcut menu that appears.
> Change the name of the file to hatten.xxx . If you receive a prompt that
> states that changing the extension may cause the file to become unusable,
> click Yes .
> Minimize, but do not close, the Find dialog box.
> On the Start Menu, point to Settings , and then click Control Panel .
> In Control Panel, double-click Add/Remove Programs .
> In the Add/Remove Program Properties dialog box, click the
Install/Uninstall
> tab, and select Microsoft Office 97, Professional Edition in the program
> list.
> Click Add/Remove to run Office Setup in Maintenance Mode.
> In the Microsoft Office 97 Setup dialog box, click Reinstall .
> After the reinstallation is finished, click the Find dialog box on the
> taskbar to maximize it.
> Under Name , right-click the hatten.xxx file, and then click Rename on the
> Change the name of the file back to hatten.ttf .
> Microsoft Access should now be properly registered.
> > Sent: Tuesday, January 15, 2002 12:26 PM
> > on this machine."
> > Troy Funte
> > Liberty Electronics
> > enable access. )
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
dhieber
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
Yahoo! Groups Links
New Price:
Two arms and both legs. I will stop there for now :-)
Daniel C. Spoerl
Estimator/MIS Manager
Toledo Metal Spinning Co.
Phone: (419) 535-5931 ext. 203
Fax: (419) 535-0565
Personal E-fax: (707) 897-1708
Email: dans@...
WebSite: http://www.toledometalspinning.com
The information in this E-mail message is confidential and may be legally
privileged and is information intended only for the use of the individual(s)
named above. If you are not the appropriate recipient, you are hereby
notified that you should not further disseminate, distribute, or forward
this E-mail message. If you have received this communication in error,
please delete the original from your system, destroy all paper copies, and
notify us immediately so we might prevent any recurrence.
We have taken reasonable steps to ensure that this message (and any
attachments or hyperlinks contained within it) are free from computer
viruses and the like. However, in accordance with good computing practice,
the recipient is responsible for ensuring that it is actually virus free
before opening it. Toledo Metal Spinning is under no duty to cover any loss
or damage caused by software viruses.
dhieber
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
Yahoo! Groups Links
Ed-
I was told and verified it by visiting last week the IRS web site that
from 9/1 -12 31 the rate was increased to $0.485 due to the gas prices.
I sort of "fibbed" to my employees and told then that this was effective
10/1 so as to not go back and recalculate/reimburse the difference!
Thanks!
Rick Ludwig
Of Edward F. Fox, Jr.
Sent: Monday, September 26, 2005 8:58 AM
Of
dhieber
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
have
and
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Online+d
atabase+software&c=6&s=185&.sig=AvWEwtBBb2CCZUYeLzjLVQ> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=On
line+database+software&c=6&s=185&.sig=8uEu2piLZhrmuaS0aRTs5A> database
software Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Onli
ne+database+software&c=6&s=185&.sig=WxJOMUVfawa-Spj4srksIw> mortgage
software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Online+da
tabase+software&c=6&s=185&.sig=8c6UocdSpoECWlSALplOdQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
line+database+software&c=6&s=185&.sig=C2nNY1SnmwAiBO61ww9nTw> management
software Online
<http://groups.yahoo.com/gads?t=ms&k=Online+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+sof
tware&w4=Pda+database+software&w5=Database+management+software&w6=Online
+database+software&c=6&s=185&.sig=cYursVrba9nF7BBMh8EfUA> database
software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
Thanks Rick.
Ludwig, Rick
Sent: Monday, September 26, 2005 10:12 AM
Ed-
I was told and verified it by visiting last week the IRS web site that from
9/1 -12 31 the rate was increased to $0.485 due to the gas prices. I sort of
"fibbed" to my employees and told then that this was effective 10/1 so as to
Thanks!
Rick Ludwig
Edward F. Fox, Jr.
dhieber
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing
Membership
software Database
software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
Database
software Online
software
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
Ed,
Thanks that is what I was looking for but the new rate until the end of the
year is .485 and your first born...
In a news release September 9, 2005, the IRS announced that the standard
mileage rate at which employees may be reimbursed for miles driven on behalf
of their employers without taxable income has been increased to 48.5 cents
per mile for miles driven after August 31 through the end of 2005. Mileage
for the first eight months of 2005 can be reimbursed at 40.5 cents per mile.
The mileage rate is the maximum amount an employer can reimburse an employee
for business-related driving without taxable income to the employee.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
Edward F. Fox, Jr.
dhieber
anywhere.
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
Yahoo! Groups Links
Yahoo! Groups Links
