Hi,
I get the same error when using either a DSN connection or a DSN-Less connection.
The webserver is running on a Windows 2000 server separate from the Vantage server.
I installed the Progress Client on the webserver to get the drivers installed.
There seems to be a registry hack or something that I have heard about in a round about way.
Charles
Charles
----- Original Message -----
Sent: Saturday, March 10, 2007 12:07 PM
Subject: [ok] RE: [Vantage] v8, OpenEdge 10, & ODBC
> I'm working with an ODBC configuration to pull data from v8 - Vantage and
> display in a webpage.
> I keep getting the following error message in my browser:
> __________________________________________________________
> Microsoft OLE DB Provider for ODBC Drivers error '80004005'
> Specified driver could not be loaded due to system error 5 (DataDirect 4.20
> 32-BIT OpenEdge SQL v10.0B).
Where is your web server and how did you load the DSN for Vantage on it?
