In ProControl the environment settings look ok, with ACCESS=ALL and
DLC=C:\DWC\DLCSERV.
There don't appear to be any orphaned Prowin32 processes.
The server directory permissions look fine with everyone having full control
and the client machine can browse the mapped directory.
As you've suggested I've created a shortcut to:
F:\DLC\bin\prowin32.exe -db F:\Vantage\db\dcdv7.db -N TCP -H
192.168.0.100 -S vntgserv -inp 1200
However all this does is launches the Progress procedure editor.
I'm contemplating wiping the test machines and installing NT4 to see if it's
something to do with my Windows 2000 setup that's causing the problem.
Paul.
DLC=C:\DWC\DLCSERV.
Paul.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, September 12, 2003 3:18 PM
Subject: RE: [Vantage] Old Vantage version problems
> Here are a few more things to try/look for.
> In Procontrol/Detail/Environment do you have ACCESS=ALL and
> DLC=C:\DLC\Progress (in 3.x it may be C:\DLCSRV\Progress).
> Note: ACCESS= and DLC= must be in caps.
> Open Task Manager and make sure you do not have any prowin32(?)
> processes running. On the client PC create a shortcut similar to:
> "V:\DLC\bin\prowin32.exe -db V:\Vantage\db\Vantage.db -N TCP -H hostname
> -S servicename -inp 1200"
> - this may give you an error message, making it easier to troubleshoot.
> Check permissions on the server. By default a Domain Admin does not have
> full permissions. I have never seen this with Vantage or Progress, but
> have had this issue with other software, had to logon as a local admin
> to install.
> HTH
> Jim
> -----Original Message-----
> From: Jasper Recto [mailto:jrecto@...]
> Sent: Friday, September 12, 2003 7:57 AM
> To: vantage@yahoogroups.com
> Are you using the default database it creates when you installed it or
> did you bring over the database from the other company. I ask because I
> think I had the same problem and it was because the database and the
> Vantage files were not on the same patch level.
> Jasper
> From: Paul Oliver [mailto:p.oliver@...]
> Sent: Friday, September 12, 2003 8:46 AM
> Subject: Re: [Vantage] Old Vantage version problems
> Thanks for the suggestions Calvin, I certainly am collecting lots of 2
> cents
> however nothing I've tried as yet has found the cause of the problem.
> I've checked the ports listed in the services file and there are no
> duplicate entries, and I've tried as you suggested using the IP address
> and
> port in the .vtg file but again this doesn't seem to make any
> difference.
> Both the server and client were clean Win 2000 installs before trying
> Vantage 3.20 so there is definitely no conflict with other versions.
> It seems as if the database isn't running (despite what ProControl says)
> as
> I get the exact same effect if I stop the database, the client displays
> the
> splash screen briefly then quits. I've checked that the server is
> responding to connections on the correct port by Telnetting to it but
> I'm
> puzzled as to why it's not working.
> Paul.
> From: "calvin" <calvin@...>
> Sent: Friday, September 12, 2003 1:33 PM
> > Paul -
> > Look for duplicate port usage in your services file.
> > There were two installs levels from DCD/Dataworks/Epicor
> > during the evolution of vantage that used the same port number.
> > If you have all these versions installed, you may have the same
> > port number in the services file referenced by two different names.
> > Likewise make sure that any newer levels of Progress and Vantage
> > have been removed from the client (primarily in the registry) and
> > you might want to also try changing the -H from the server name
> > to it's IP address and the -S from the name to it's Port number in
> > the vtg file.
> > Hope my two cents helps. With enough luck by the time your
> > done collecting all the two cents you'll have enough for a beer!
> > HTH,
> > Misha 1, Ltd
> > Calvin Dekker
> > From: Paul Oliver <p.oliver@...>
> > Sent: Friday, September 12, 2003 3:09 AM
> > > Everything looks fine in the .vtg and .ini files, the paths appear
> to be
> > > correct and the service settings look to be OK.
> > > Paul.
> > > From: "Chris Robisch" <crobisch1@...>
> > > Sent: Thursday, September 11, 2003 8:14 PM
> > > > Double check the .ini and .vtg (.mfg) files. Sometimes, even the
> working
> > > > directory is pointing to the wrong drive which would cause your
> problem.
> > > > From: "Paul Oliver" <p.oliver@...>
> > > > Sent: Thursday, September 11, 2003 8:00 AM
> > > > > Hosts and Services on both the server and client machines both
> look
> > > fine,
> > > > > the installer had made correct entries there.
> > > > > Paul.
> > > > > From: "Todd Caughey" <caugheyt@...>
> > > > > Sent: Thursday, September 11, 2003 3:43 PM
> > > > > > Just a wild stab but double check the HOSTS and SERVICES files
> for
> > > > proper
> > > > > entries and port numbers. I've seen the installation not get
> this
> > right
> > > a
> > > > > time or two.
> > > > > > -Todd C.
> > > > > > Sent: Thursday, September 11, 2003 8:49 AM
> > > > > > Both the server and the client were clean Windows 2000
> installs,
> and
> > > > other
> > > > > > versions of Vantage (4.0 and 5.0) work fine on this hardware
> setup.
> > > It
> > > > > was
> > > > > > reformatted again before attempting to install 3.20.
> > > > > > I've now tried installing and running the client from the
> server
> > > itself
> > > > > and
> > > > > > I get the same result however this time I do get an error in
> the
> > event
> > > > > log:
> > > > > > MrxSmb - The redirector failed to determine the connection
> type
> > > > > > This sounds like a network problem however the MS knowledge
> base
> > > article
> > > > > at
> http://support.microsoft.com/default.aspx?scid=kb;en-us;q267934
> says
> > > it
> > > > > can
> > > > > > be safely ignored.
> > > > > > Paul.
> > > > > > From: "Jasper Recto" <jrecto@...>
> > > > > > Sent: Thursday, September 11, 2003 2:29 PM
> > > > > > > I had to upgrade from 3.2 to 5.2 recently. I also installed
> 3.2
> > on
> > > > > > Windows 2000 to do test runs. I had no problems with the
> > > installation.
> > > > > Can
> > > > > > you run vantage on the server itself? Try that to see if it's
> a
> > > server
> > > > > > issue or a client issue. Was there a different version of
> vantage
> > on
> > > > any
> > > > > of
> > > > > > these systems before you installed 3.2? If there was, there
> is
> > > probably
> > > > > > still references to that version. Try to use completely clean
> > > machines
> > > > to
> > > > > > install 3.2.
> > > > > > > Jasper
> > > > > > > Sent: Thursday, September 11, 2003 5:42 AM
> > > > > > > Subject: [Vantage] Old Vantage version problems
> > > > > > > We have an unusual situation in which I am attempting to
> install
> a
> > > > very
> > > > > > old
> > > > > > > version of Vantage (3.20) on a modern system. Epicor UK
> support
> > > have
> > > > > been
> > > > > > > helpful but haven't been able to help me much so I thought
> I'd
> ask
> > > > here.
> > > > > > > Firstly let me explain why I need to do this. We currently
> run
> > > Vantage
> > > > > > 5.20
> > > > > > > on our main system (soon to upgrade to 6.00) and we have
> recently
> > > > bought
> > > > > > > another company that is still running Vantage 3.20 on an old
> NT
> > > > server.
> > > > > > > The decision has been made to bring them up to the same
> Vantage
> > > > version
> > > > > as
> > > > > > > us so to do this I have set up a test server and workstation
> > > (Windows
> > > > > 2000
> > > > > > > server and pro, both SP4) in order to test the upgrade
> process
> > (3.2
> > > to
> > > > > 4.0
> > > > > > > to 5.0 to 5.2).
> > > > > > > However despite following the installation instructions to
> the
> > > letter
> > > > I
> > > > > > > cannot get Vantage 3.20 running on the test systems.
> Progress
> > 8.3A
> > > > and
> > > > > > > Vantage appear to install correctly with no error messages
> and
> > > > > ProControl
> > > > > > > seems to run fine on the server. When I try to launch
> Vantage
> > from
> > > > the
> > > > > > > client machine all I get is the splash screen appearing for
> about
> > > 0.5
> > > > > > > seconds then vanishing. No errors are logged in the error
> logs
> on
> > > > > either
> > > > > > > the server or client machine and looking at task manager on
> the
> > > client
> > > > > > > machine it appears that the client simply aborted as there
> are
> no
> > > > > running
> > > > > > > processes.
> > > > > > > This has got me well and truly stumped! Any helpful
> suggestions
> > or
> > > > > > > troubleshooting advice would be appreciated. I'm wondering
> > whether
> > > > > > Vantage
> > > > > > > 3.2/Progress 8.3A is incompatible with Windows 2000 so maybe
> I
> > > should
> > > > > try
> > > > > > > the process again under NT4? Has anyone every tried running
> 3.20
> > on
> > > > > > Windows
> > > > > > > 2000 before?
> > > > > > > Paul Oliver
> > > > > > > Network Manager
> > > > > > > Concentric Controls Ltd.
> > > > > > > This e-Mail (and any attachments) should only be read by the
> > > intended
> > > > > > > addressee(s) and not be relied upon without subsequent
> written
> > > > > > confirmation
> > > > > > > of its contents. Concentric Controls Ltd. accepts no
> liability
> for
> > > the
> > > > > > > consequences of any person acting on such information prior
> to
> the
> > > > > receipt
> > > > > > > of such confirmation. If you are not the intended recipient,
> you
> > are
> > > > not
> > > > > > > authorised to, and must not use, disclose, copy, distribute,
> or
> > > retain
> > > > > > this
> > > > > > > message, its attachments or any part thereof. Any views or
> > opinions
> > > > > > > expressed are those of the author and do not necessarily
> reflect
> > the
> > > > > > > opinions of Concentric Controls Ltd.
> > > > > > > Concentric Controls Ltd. www.concentriccontrols.com
> > > > > > > Priory Road, Aston, Birmingham B6 7LH, UK
> > > > > > > Tel: +44 (0)121 327 1662 Fax: +44 (0)121 328 2498
> > > > > > > Yahoo! Groups Sponsor
> > > > > > > ADVERTISEMENT
> http://rd.yahoo.com/M=244522.3707890.4968055.1261774/D=egroupweb/S=17050
> 071
> > > > > > 83:HM/A=1595053/R=0/SIG=124gf29oe/*
> > > > > http://ashnin.com/clk/muryutaitakenattogy
> > > > > > o?YH=3707890&yhad=1595053> Click Here!
> http://us.adserver.yahoo.com/l?M=244522.3707890.4968055.1261774/D=egroup
> mai
> > > > > > l/S=:HM/A=1595053/rand=213965276>
> > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> > > must
> > > > > > have already linked your email address to a yahoo id to enable
> > > access. )
> > > > > > > (1) To access the Files Section of our Yahoo!Group for
> Report
> > > Builder
> > > > > and
> > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > > > (2) To search through old msg's goto:
> > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > > (3) To view links to Vendors that provide Vantage services
> goto:
> > > > > > http://groups.yahoo.com/group/vantage/links
> > > > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service
> > > > > > < http://docs.yahoo.com/info/terms/> .
> > > > > > > [Non-text portions of this message have been removed]
> You
> > > must
> > > access. )
> Report
> > > Builder
> > > > > and
> goto:
> http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=17050
> 071
> 83:HM/A=1524963/R=0/SIG=12o885gmo/*
> http://hits.411web.com/cgi-bin/autoredir?
> > > > > camp=556&lineid=3614674&prop=egroupweb&pos=HM>
> http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroup
> mai
> > > > > l/S=:HM/A=1524963/rand=355202160>
> You
> > must
> > access. )
> > > > > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > > and
> goto:
> Service
> You
> > must
> > access. )
> > Builder
> > > > and
> goto:
> You
> must
> access. )
> Builder
> > > and
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> access. )
> Builder
> > and
> must
> > have already linked your email address to a yahoo id to enable access.
> Builder
> and
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> ADVERTISEMENT
> <http://rd.yahoo.com/M=251812.3856299.5103760.1261774/D=egroupweb/S=1705
> 007183:HM/A=1754452/R=0/SIG=11tjeu2hk/*http://www.netflix.com/Default?mq
> so=60178324&partid=3856299> click here
> <http://us.adserver.yahoo.com/l?M=251812.3856299.5103760.1261774/D=egrou
> pmail/S=:HM/A=1754452/rand=654784018>
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
