OldServer equals NewServer
I don't need to remove this. I had just posted it and discovered the
solution so I didn't want to bother everyone. You can leave it out
there.
--- In vantage@yahoogroups.com, Rubberasc@... wrote:
> Technically, you can do as you describe. However, be prepared for an
assortment of cleanup tasks. If your system has been around for a
while you've made use of that server name in a number of different
areas. You potentially could cut off some users or some applications
from your server. Also, software installs could potentially have used
the server name. Depending on the number of machines in your network,
I would take a close look at EVERYONE's installed applications to see
if there's any impact.
> Shirley Graver
> Sys Admin
> Rubber Associates
