thanks again!
Kunal
----- Original Message ----
Sent: Friday, May 16, 2008 3:59:41 PM
Subject: Re: [Vantage] Re: On Error Resume Next - question
Another trick that works is to set a custom epiTextBox = edvPODetail. dataView( edvPODetail. Row)("PONum" ))
Calling it txtEpiCustPONum, your code is then:
Private Sub txtEpiCustPONum_ ValueChanged( ByVal Sender As Object, ByVal Args As System.EventArgs) Handles txtEpiCrelQty. ValueChanged
If len(txtEpiCustPONum .text) <> 0 then
'//** If in an app like PO Entry where no editing can occur
'//** unless PO is unapproved,
'//** also test POHeader.ApprovalSt atus
If edvPOHdr.dataView( edvPOHdr. Row)("ApprovalSt atus") = "U" then
'//** Do your stuff **
end if
End If
End Sub
This works when epiNotifications are unreliable for the app being modified & when after_adaptermethod triggers don't exist that are appropriate.
Rob Brown
Kunal
end if
End If
End Sub
Rob Brown
--- On Fri, 5/16/08, bw2868bond <bwalker@adcocircuit s.com> wrote:
Subject: [Vantage] Re: On Error Resume Next - question
To: vantage@yahoogroups .com
Date: Friday, May 16, 2008, 1:45 PM
In the properties window for the button - make the enabled property
False
when you detect that you have a PONum (like watch the dataview
initialize event and when the row count is not -1) set the property
to true (btnClickMe. Enabled = True) - you will have to also set it
back to false when the PONum is not valid
Just a thought - there are many ways to accomplish preventing the
error.
--- In vantage@yahoogroups .com, Kunal Ganguly <kunal_vantage@ ...>
wrote:
> Keep the button not enabled until there is a valid PONum ?
> How would I do that? Is that some setting in the customizations
interface?
> Thanks,
> Kunal
> From: bw2868bond <bwalker@... >
> Sent: Friday, May 16, 2008 12:24:25 PM
> --- In vantage@yahoogroups .com, "Mark Wonsil" <mark_wonsil@ ...>
wrote:
> > > Here is my code for a button event in the PO entry form, it
> essentially
> > > launches an external app I wrote in VB which looks up some
stuff in
> a SQL DB
> > > separate from vantage, but it needs data from this form -
> > Would testing for a null entry work?
> > If Not IsNull(edvPODetail. dataView( edvPODetail. Row)("PONum" ))
then
> > process.start( "c:\engdrawdatav 2.exe",
> > end if
> > Mark W.
