I linked them as you said and it works just fine now.
Thank You!
Thank You!
--- In vantage@yahoogroups.com, "smithjennifer79" <jsmith@...> wrote:
> I have created on in Crystal but have ran into a few minor issues. I
> orig. set up the report to pull the need by & req. by dates from the
> header tab but should really be pulling them from the releases tab as
> they can very. I also need the ship by date (only found in the
> shiphead, that i'm aware of). So so far the tables i am using are
> shipdtl, shiphead, orderhed, customer. When i add orderrel and then
> put the needby date & req.date on the report from the releases table
> the report goes crazy and isn't correct anymore. When i use the
dates
> from orderhed, the info is 100% accurate. Am i linking these wrong?
> Thanks,
> Jennifer
> jsmith@...
