One more bar code question
That worked perfectly. Thanks!!!
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@v...> wrote:
> Kelly,
> You will have to use the replace function to replace occurrences of
/ with
> /O (the full asci for /).
> If you need more specific instruction, feel free to ask.
> Aaron Hoyt
> Vantage Plastics
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
> Of wendorff1
> Sent: Wednesday, May 11, 2005 12:28 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] One more bar code question..
> I'm trying to simplify our labor collection process by bar coding
> several commonly used indirect labor codes. Specifically, I'm trying
> to bar code the entry for Indirect Code "20" on the WorkCenter ID
> "T/LSR".
> Based on what I've learned from the forum, this formula should work.
> "*" & Trim ({Indirect.IndirectCode}) & "$I" & Trim
> ({WrkCenter.WCCode}) & "*"
> The forumla works appears to work without error. I have setup my bar
> code gun to read FULL ASCII.
> When the gun scans the code, it converts the /L in the "T/LSR" to a
> comma. The output reads "20 T,SR" (the space represents the tab
> movement).
> Any suggestions?
> Thanks!
> Kelly
must have
Builder and
> Yahoo! Groups Links
"T/LSR".
movement).
Any suggestions?
Thanks!
Kelly
Kelly,
You will have to use the replace function to replace occurrences of / with
Aaron Hoyt
Vantage Plastics
Of wendorff1
"T/LSR".
movement).
Any suggestions?
Thanks!
Kelly
Yahoo! Groups Links
