One more reason why progress should die
The purpose of this adventure was to move data from the MtlQueue records to the PartTran records at Issue or Return. In this case specifically to capture the create date and time of the MtlQueue record so that we can compare the create date/time of the queue record against the create date/time of the PartTran for delivery and pickup time reporting. Never thought we would get it with a crazy hex string like that!
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
----- Original Message -----
To: "Vantage" <vantage@yahoogroups.com>
Sent: Friday, June 14, 2013 10:18:22 AM
Subject: Re: [Vantage] One more reason why progress should die
Its SQL
Progress -> ODBC -> SQL
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Fri, Jun 14, 2013 at 11:11 AM, Chad Villa <chad.villa@...> wrote:
> Jose,
> Was that system using a dataserver to a SQL db or was it an actual Progress
> database?
> I didn't think it was possible to overwrite a ROWID with what you saw. I'd
> be 'impressed' if Epicor managed that.
> Thanks,
> Chad
> On Fri, Jun 14, 2013 at 9:48 AM, Jose Gomez <jose@...> wrote:
> > Yeah i think its just progress being progress they do use a integer
> REC_ID
> > but the actual ROWID() that comes back is that hex string where clause
> > nightmare.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Fri, Jun 14, 2013 at 10:47 AM, Vic Drecchio
> > <vic.drecchio@...>wrote:
> > > Maybe you're right... That just seems like an unbelievable
> > limitation/PITA
> > > of a db server.
> > > Why not use a sequential integer?
> > > ...smh....
> > > -----Original Message-----
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > > Of
> > > Jose Gomez
> > > Sent: Friday, June 14, 2013 10:35 AM
> > > To: Vantage
> > > So development made the row ids be that? I thoguht ROWID and TO-ROWID
> > was a
> > > Progress Function?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > On Fri, Jun 14, 2013 at 10:31 AM, Vic Drecchio
> > > > That's the best subject line I've seen in a while. I second that. But
> > > > in Progress' defense, this is a development issue. This could be done
> > > > in SQL, Oracle or dBase III+.
> > > > Just like the stupid ~ separating Sales Rep IDs.
> > > > Behalf Of Jose Gomez
> > > > Sent: Friday, June 14, 2013 10:10 AM
> > > > To: Vantage
> > > > Subject: [Vantage] One more reason why progress should die
> > > > Working on a Customization we needed to get a hold of the MTL Queue.
> > > > In the trace there is
> > > > MtlQueueRowID=
> 0x003d0baf00010000574845524520282850524f47524553535f5245434944203d2000
> > > > 000058
> > > > 0008fffb00000000000000000000000000007b9729292000
> > > > Which looking at the DB doesn't match anything in the record. Bummed
> > > > out we tried to translate the RowID from Hex to ASCI. Which some how
> > > > worked and we got
> > > > ?=??????WHERE ((PROGRESS_RECID = ???X??????????????????{?)) ?
> > > > So we assumed that ???X??????? was the actual REC_ID but it was a HEX
> > > > number not a Hex String. So after more poking around we got the
> REC_ID
> > > > 07b97
> > > > which translated to 31653 which was the MTL Queue we needed. Excited
> > > > we wrote some ABL to Parse that bohemoth and end up with the Mtl
> Queue
> > > > ID so that we could do some other stuff.
> > > > When running a query such as
> > > > FOR EACH MtlQueue WHERE ROWID(MtlQueue)=TO-ROWID(MyParsedString):
> > > > END.
> > > > The results were not appearing and out of curiosity I decided to
> > > > display the RowID of any MtlQueue
> > > > FOR FIRST MtlQueue:
> > > > DISPLAY STRING(ROWID(mtlQueue)).
> > > > END.t
> > > > To my surprise it returned
> > > > 000058
> > > > 0008fffb00000000000000000000000000007ba529292000
> > > > Which is an identical string to the original one I parsed... So
> ladies
> > > > and gentlemen apparently Progress indexes and stores their data with
> a
> > > > WHERECLAUSE AS THER FREAKING RECORD ID.
> > > > *FACE PALM*
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@... <mailto:jose%40josecgomez.com>
> > > > http://www.josecgomez.com <http://www.linkedin.com/in/josecgomez>
> > > > [Non-text portions of this message have been removed]
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
MtlQueueRowID= 0x003d0baf00010000574845524520282850524f47524553535f5245434944203d20000000580008fffb00000000000000000000000000007b9729292000
Which looking at the DB doesn't match anything in the record. Bummed out we
tried to translate the RowID from Hex to ASCI. Which some how worked and we
got
number not a Hex String. So after more poking around we got the REC_ID 07b97
which translated to 31653 which was the MTL Queue we needed. Excited we
wrote some ABL to Parse that bohemoth and end up with the Mtl Queue ID so
END.
The results were not appearing and out of curiosity I decided to display
FOR FIRST MtlQueue:
END.t
0x003d0baf00010000574845524520282850524f47524553535f5245434944203d20000000580008fffb00000000000000000000000000007ba529292000
Which is an identical string to the original one I parsed... So ladies and
gentlemen apparently Progress indexes and stores their data with a
*FACE PALM*
*Jose C Gomez*
*Software Engineer*
E: jose@...
That's the best subject line I've seen in a while. I second that. But in
Progress' defense, this is a development issue. This could be done in SQL,
Jose Gomez
To: Vantage
MtlQueueRowID=
got
END.
FOR FIRST MtlQueue:
END.t
*FACE PALM*
*Jose C Gomez*
*Software Engineer*
So development made the row ids be that? I thoguht ROWID and TO-ROWID was a
Progress Function?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Of
> Jose Gomez
> To: Vantage
> MtlQueueRowID=
> got
> 07b97
> END.
> FOR FIRST MtlQueue:
> END.t
> *FACE PALM*
> *Jose C Gomez*
> *Software Engineer*
Maybe you're right... That just seems like an unbelievable limitation/PITA
of a db server.
...smh....
Jose Gomez
To: Vantage
Progress Function?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> To: Vantage
> MtlQueueRowID=
> 000058
> worked and we got
> 07b97
> we wrote some ABL to Parse that bohemoth and end up with the Mtl Queue
> END.
> FOR FIRST MtlQueue:
> END.t
> 000058
> and gentlemen apparently Progress indexes and stores their data with a
> *FACE PALM*
> *Jose C Gomez*
> *Software Engineer*
Yeah i think its just progress being progress they do use a integer REC_ID
nightmare.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> of a db server.
> ...smh....
> Of
> Jose Gomez
> To: Vantage
> Progress Function?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > To: Vantage
> > MtlQueueRowID=
> > 000058
> > worked and we got
> > 07b97
> > END.
> > FOR FIRST MtlQueue:
> > END.t
> > 000058
> > *FACE PALM*
> > *Jose C Gomez*
> > *Software Engineer*
Jose,
database?
Chad
> nightmare.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> limitation/PITA
> > of a db server.
> > ...smh....
> > Of
> > Jose Gomez
> > To: Vantage
> was a
> > Progress Function?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > To: Vantage
> > > MtlQueueRowID=
> > > 000058
> > > worked and we got
> > > 07b97
> > > END.
> > > FOR FIRST MtlQueue:
> > > END.t
> > > 000058
> > > *FACE PALM*
> > > *Jose C Gomez*
> > > *Software Engineer*
> have
Its SQL
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
> database?
> Thanks,
> Chad
> REC_ID
> > nightmare.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > limitation/PITA
> > > of a db server.
> > > ...smh....
> Behalf
> > > Of
> > > Jose Gomez
> > > To: Vantage
> > was a
> > > Progress Function?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > To: Vantage
> > > > MtlQueueRowID=
> > > > 000058
> > > > worked and we got
> REC_ID
> > > > 07b97
> Queue
> > > > END.
> > > > FOR FIRST MtlQueue:
> > > > END.t
> > > > 000058
> ladies
> a
> > > > *FACE PALM*
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > have
> and
