Yup. That will work if you only have one backflush whse/bin per part.
We have up to half a dozen (so must control at resource).
If you can get away with it though, it doesn't get any easier than that. (Great idea!)
Rob
Rob
--- On Fri, 3/6/09, Rick Bird <rbird@...> wrote:
Subject: [Vantage] Re: One Resource, Two Warehouses
Date: Friday, March 6, 2009, 10:13 AM
I beleive I have found a possible 4th option. I tripped across this option while working on a backflushing problem call with Phil G. @ Epicor, this sounds like something that would work for us.
Option 4: Logic provided below option description
1. Leave the Resource/Resource Group Backflush Warehouse & Bin's blank.
2. Confirm that all parts have a Primary Warehouse & Primary Bin properly configured.
3. Do NOT add/remove any Operations or Resources/Resource Groups, leave as is.
Here is why this may work:
Per the backflush Hierarchy publish on Page 9733MPS, if configured as above any parts related to an operation will backflush from that parts Primary Warehouse & Primary Bin, #2 below:
AMM Warehouse Backflush Hierarchy:
1. FROM THE RESOURCE GROUP (of the linked job operation) Backflush warehouse and bin - IF it exists and if a positive on hand quantity exists at this location if they are defined. (can also use a Resource backflush WH and Bin IF that is the scheduling requirement on an operation if no RG is related to the Operation)
2. USE THE PRIMARY BIN FOR THE PART IN THE ALLOCATED WAREHOUSE.
(JobMtl.WarehouseCo de) if it is defined. Allocated WH is the WH
selected in the job's material requirement sequence screen -- which defaults to the material part's primary WH from the part master).
3. If Primary bin is NOT defined for the part in the allocated warehouse back in the part master then take the first bin with a positive on hand quantity. If no qty exists in any bin, then .....
4. Use the first bin in the list of warehouses for this warehouse.
5. If for some reason no warehouse/bin can be determined then the part will not be back flushed.
For the vast majority of our parts this will work because the component parts are stored in the same warehouse as the product being produced, and we do not have a lot of warehouse bins, like maybe a half dozen(we do not employ the bin concept as an actual BIN). For instance, we are producing a Scaffold frame, well the raw materials are stored in SCAF/RAW and the locks and such are stored in SCAF/ASSEM. Well, when welding is welding a raw part, the Weld operation will backflush that raw part from that parts primary bin in SCAF, which is RAW. Later when the paintline is attaching locks to the painted frame, the locks and powder are stored in SCAF/ASSEM and that is their primary bin, so when the PAINT Op reports the parts will then backflush from..... the same location.
I think this will work, for exceptions, and we do have them, I can attempt employing, either my Option 2 or Rob's Option 3, depending. I think this approach to the solution will result in the least amount of re-engineering, which is a big deal here. My only concern is:
will the changes made to the resource/resource groups, automatically updated their referenced OPs? If so, then how do I get the OP's to then update the methods (I've noticed that if I make change to an OP it does not affect any already deployed methods). Maybe I should post this in another Post.
Please, provide feedback on my 4th Option, on any opinions, or anything I am not thinking about. AND what type of problems is there with updating Resources/Groups and getting those to update OPs and/or Methods?
--- In vantage@yahoogroups .com, "Rick Bird" <rbird@...> wrote:
> We have a problem here that maybe someone can enlighten us on how to
> deal with.
> Almost every machine (presses, drills, benders, etc) is used on jobs
> that manufacture parts for both of the Divisions of our business
> (scaffold & aerial work platforms). Right now we have one to one
> relationship between the resource and an operation, for instance:
> Resource: 524 (a saw) --> OP "Saw." Well this saw may be used to cut
> tube for scaffolding, or larger square tube for work platforms. But
> the raw material that feeds the op (resource) is stocked in different
> Warehouse/Bin' s. (Scaffold = SCAF/RAW & Aerial Work Platforms =
> AWP/RAW) Inventory is stocked per accounting, they need to know on
> hand inventory costs for each division. But the resource is only be
> configured to backflushed from one predetermined warehouse/bin. What
> is the best way to set up resources/operation s to fit this situation?
> Since this is not configured correctly, it is causing On Hand
> problems since depending on what division a job is manufacturing for
> the resource may backflush from the wrong bin (SCAF when it should be
> AWP). The option of NOT backflushing will not work because of the
> huge number of parts that would have to be manually issued, for which
> we do not have the man power for.
> Options we have come up with:
> 1. configuring 2 resource records for each resource (ex: AWP Saw &
> SCAF Saw), the only problem with that is that there is actually only
> ONE physical saw and then scheduling of the resource becomes a
> problem, since it sees that there are two resources available to
> schedule when there is actually only one.
> 2. Configure 1 resource, but place that resource in two resource
> groups, one for AWP and one for SCAF. Once again our concern is the
> same, will Vantage schedule the Resource Group in respect of there
> being only one Resource to schedule or not? Does the Resource Group
> backflush bin config override the Resource backflush bin?
> Neither really addresses the issue correctly.
> any have any ideas based on maybe what your company does?
