at Infragistics.Shared.KeyedSubObjectsCollectionBase.GetItem(String key)
at Infragistics.Win.UltraWinGrid.ColumnsCollection.get_Item(String key)
at Infragistics.Win.UltraWinGrid.SortedColumnsCollection.Add(String key, Boolean descending)
at Ice.Lib.Framework.EpiUltraGrid.LayoutLoadFromXml(XmlDocument gridLayout)
If she clicks OK to close the error, she can select the dates and run the BAQ.
It doesn’t matter if she uses the modern shell or classic style and the error occurs when she logs in at someone else’s workstation.
I would guess that it is personalization-related, because of this: “at Ice.Lib.Framework.EpiUltraGrid.LayoutLoadFromXml(XmlDocument gridLayout)”.
The error is happening as the grid is attempting to load the user’s personalized grid layout. Try deleting or resetting the personalization and try again.
