Open Crystal Report from MES
Nancy, assign this to the Click() event of your button.
ProcessCaller.LaunchForm(oTrans,"UDXXXX")
Where, "UDXXXX" above is your menu ID created in Menu Maint in Epicor.
Nancy Dornacker
Sent: Wednesday, March 05, 2014 8:33 AM
Subject: [Vantage] Open Crystal Report from MES
We are using Epicor 9.05.702a along with MES.
I have a Crystal report which has been setup as a Report Style using Crystal
Reports. I have it on a menu, using Menu Maintenance in Epicor. The report
opens fine there. It uses Epicor.Mfg.UI.CustomReport.dll to open the
report.
Now, I would like to put this report on the MES form. I have created a
button. How can I call this report style from the button click event
through MES?
Please provide sample code in your reply. Thanks.
I have a Crystal report which has been setup as a Report Style using Crystal Reports.  I have it on a menu, using Menu Maintenance in Epicor.  The report opens fine there.  It uses Epicor.Mfg.UI.CustomReport.dll to open the report.
Now, I would like to put this report on the MES form.  I have created a button.  How can I call this report style from the button click event through MES?
Nancy -
Have you tried?:
ProcessCaller.LaunchForm(oTrans, menuItem)
menuItem is the menu id from menu maintenance.
Thank you in advance,
Calvin Dekker
[cid:image001.jpg@01CF3845.F5B4CF00]<http://www.codabears.com/>
630-672-7688 x1484
[cid:image002.png@01CF3845.F5B4CF00] <https://www.facebook.com/CodaBearsInc> [cid:image003.png@01CF3845.F5B4CF00] <http://www.linkedin.com/company/codabears-inc> [cid:image004.png@01CF3845.F5B4CF00] <https://twitter.com/CodaBearsInc>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nancy Dornacker
Sent: Wednesday, March 5, 2014 7:33 AM
