I haven't look at the exact program you are calling but not all programs will automatically process the value you pass to it via the launch options. You may have to put a customization on the called program to handle the values passed to it and kick off the oTrans.Method (ie. oTrans.GetByID(partnumber)) appropriate to load the screen.
Jim Kinneman
Encompass Solutions, Inc
Jim Kinneman
--- In vantage@yahoogroups.com, "Anon" <jgiese@...> wrote:
> Just a bit of a bump on this, I'm really hoping someone can help me. I've called Epicor and got some more bounce around on this so.... :S
> --- In vantage@yahoogroups.com, "Anon" <jgiese@> wrote:
> > I am trying to open the HH Move Inv screen from the HH Pack out screen with a button on the lines tab. Epicor 9.05.607A. I have the below code in my customization, and it launches the UI but I can't get it to pass the part number
> > private void btnMvInt_Click(object sender, System.EventArgs args)
> > // ** Place Event Handling Code Here **
> > Control txtPartNum = csm.GetNativeControlReference("5bfd1d21-4956-4b6b-8bbc-d7b575109f95");
> > LaunchFormOptions opts = new LaunchFormOptions();
> > opts.IsModal = false;
> > opts.SuppressFormSearch = true;
> > opts.ValueIn = txtPartNum.Text;
> > ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UI.HHInvTransferEntry", opts);
> > If I use a messagebox show txtPartNum.Text does return the part number I expect from the PackOut.PartNum field on the lines tab. What am I missing?
