Open PO Entry after generating a PO
I am trying to bring up the PO entry form after a user generates a new PO from New PO Suggestions. Currently when you generate a PO from here the details and everything disappears and that's all you get, the user then has to go find the PO manually. I did a trace and during the Generate method I see nowhere where it assigns the PO number. Would it work if I did a search against the PO table after the generate method which I hope would return the newest PO that was just generated and then call the PO entry screen with that PO number. I am curious if anyone has done this or a similar customization.
Thanks in advance,
Ted
