Open Specific Windows
Nice , i never used the file Menu ;)
But i got this error :
Error Detail
Could not access 'CDO.Message' object.
Stack Trace
at System.Web.Mail.LateBoundAccessHelper.CallMethod(Object obj, String methodName, Object[] args)
at System.Web.Mail.CdoSysHelper.Send(MailMessage message)
at System.Web.Mail.SmtpMail.Send(MailMessage message)
at Epicor.Mfg.UI.FrameWork.EpiUIUtils.EMailShortCut(String eText, String shortCutFileName)
Inner Exception
Exception has been thrown by the target of an invocation.
Seems our version is not correctly configure, i m gonna give this pb to our distributor.
Thanks a lot..
--- In vantage@yahoogroups.com, Waffqle Driggers <waffqle@...> wrote:
> From pretty much any screen it should be under,
> File > Send > 'Record by Email'
> On Mon, Nov 22, 2010 at 10:13 AM, MirTech <mirtech2009@...> wrote:
> > Hi waffqle
> > Happy to know that's it's possible by a specific .mfgsys file.
> > The Problem it that i dont' have , or i don't know how to find the
> > 'send record by email' function in Epicor, can you help me on this ?
> > Thanks a lot.
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Waffqle
> > Driggers <waffqle@> wrote:
> > > Yeah. You create an .mfgsys file. It's basically an xml file.
> > > Do the 'send record by email' function in Epicor. That will give you one
> > of
> > > those files. It's not too hard to look and see what you need to change.
> > > On Fri, Nov 19, 2010 at 9:11 AM, MirTech <mirtech2009@> wrote:
> > > > Hi All,
> > > > Just wondering if there a way to call specific windoex from a windows
> > or a
> > > > web application, for example if i got the order number i'd to open
> > order
> > > > entry on this order #, by a special command line or other way ?
> > > > Thanks,
> > > > Fred.
Hi All,
Just wondering if there a way to call specific windoex from a windows or a web application, for example if i got the order number i'd to open order entry on this order #, by a special command line or other way ?
Fred.
Do the 'send record by email' function in Epicor. That will give you one of
On Fri, Nov 19, 2010 at 9:11 AM, MirTech <mirtech2009@...> wrote:
> Hi All,
> Thanks,
> Fred.
Hi waffqle
Thanks a lot.
> > Hi All,
> > Thanks,
> > Fred.
> Hi waffqle
> Thanks a lot.
> of
> > > Hi All,
> or a
> order
> > > Thanks,
> > > Fred.
