Open UI function from external program
Wow! Thanks for the fast reply. I will check this out!
Charles
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Easy,
> Open Part Entry and Select a Part
> GO to File -> Send -> Record to File
> take that file and find your part number, and replace with something like
> <<REPLACEME>>>
> Then when you push the button in Excel, open that file and replace the
> <<REPLACEME>> with the part number save it as a temporary file
> then call Mfgsys.exe \CONFIG=yournewtempfile... or just register the mfgsys
> extensio with Vantage.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Fri, Sep 7, 2012 at 1:21 PM, CharlieScott <charles.parnham@...>wrote:
> > Thank you for letting me attend this group!
> > Perhaps I am using the wrong keywords but I am not finding an answer from
> > previous posts.
> > I would like to open the user interface from an external program. For
> > example, from a Microsoft Excel worksheet showing a list of parts, have a
> > column of VBA buttons that would open the Part Display screen with the
> > indicated part displaying.
> > Another example might be a Java script attached to a button on a Servoy
> > interface that shows active jobs, where the button would open the Job
> > Tracker function already populated with the indicated job.
> > I got the buttons, but I don't have a clue on how to trigger the UI to
> > open or open to a given record. Is there a way?
> > Thanks for any advice!
> > Charles
Perhaps I am using the wrong keywords but I am not finding an answer from previous posts.
I would like to open the user interface from an external program. For example, from a Microsoft Excel worksheet showing a list of parts, have a column of VBA buttons that would open the Part Display screen with the indicated part displaying.
Another example might be a Java script attached to a button on a Servoy interface that shows active jobs, where the button would open the Job Tracker function already populated with the indicated job.
I got the buttons, but I don't have a clue on how to trigger the UI to open or open to a given record. Is there a way?
Charles
Easy,
<<REPLACEME>>>
*Jose C Gomez*
*Software Engineer*
E: jose@...
> previous posts.
> Charles
