OpenLink ODBC drivers
We had no success in using the Merant ODBC drivers with Crystal
Enterprise, and switched to the OpenLink Multi-Tier ODBC driver, and
have had nothing but success. The key is that you can tell it not to
prompt you for a logon/password. It also requires a registry edit
for use with Vantage 4.0, just like Merant, but with driver name
olod4032. You may email me directly if you still need assistance.
--- In vantage@y..., "Jim Stetter" <jimstetter@s...> wrote:
> I am attempting to install and configure the OpenLink ODBC drivers
(as
> suggested by Ted Kitch several days ago) without success. I have
opened a
> case with OpenLink's support but have not gotten a satisfactory
solution.
> If anyone has successfully installed the OpenLink drivers I would
really
> like to hear from you.
> The following is the error I encountered when configuring the
driver:
> conection failed
> SqlState="S1000",NativeError=0,ErrorMsg="[OpenLink][ODBC][Progress
> Server]This client is not licensed for remote connections (4406)"
> SqlState="08004",NativeError=0,ErrorMsg="[OpenLink][ODBC]Connection
rejected
> by data source"
> This is the response from OpenLink's support:
> This error indicates that you are trying to establish a sockets
connection
> to a database which does not allow it. You will need to obtain an
> appropriate license from Progress Software.
> Maybe I am totally off base, but aren't our client connections to
Progress
> sockets connections. If not, why do you supply socket connection
parameters
> in the vantage.pf? It's the end of a loonnngg week and and
frustrated. Any
> help would be appreciated.
> Thanks to all
> Jim Stetter
> Snow Filtration
Please excuse my ignorance on this subject. I have been thrown into a
project that I do not know anything about. I am hoping someone out
there can give me some help.
I am installing Linux Red Hat 7.1 to be used for our DSL Line. I
believe I need to install the kernal for ip masquerading. I can not
find any documentation for this anywhere. I can find it on every
version before 7.1. Does anyone have any idea where I can find it or
have an idea where to begin?
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100
(412) 963-9511
www.vamcointernational.com
Patch 5.00.320 is now available.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
http://www.neon-products.com/
mailto:rnewell@...
This message is intended only for the use of the person(s) ("intended
recipient")
to whom it is addressed. It may contain information which is privileged and
confidential.
If you are not the intended recipient please contact the sender as soon as
possible.
Accordingly any dissemination, distribution, copying or other use of this
message or any
of its content by any person other than the Intended Recipient is strictly
prohibited. We
have taken every precaution to ensure that this message is virus free but
we can not be
responsible for any damage that may be caused by its content.
Sent: Friday, May 11, 2001 9:20 AM
To: vantage@onelist.com
Subject: [Vantage] [Off Topic] Linux 7.1
Dina M. Hieber
555 Epsilon Drive
(412) 963-7100
(412) 963-9511
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
I am attempting to install and configure the OpenLink ODBC drivers (as
suggested by Ted Kitch several days ago) without success. I have opened a
case with OpenLink's support but have not gotten a satisfactory solution.
If anyone has successfully installed the OpenLink drivers I would really
The following is the error I encountered when configuring the driver:
conection failed
SqlState="08004",NativeError=0,ErrorMsg="[OpenLink][ODBC]Connection rejected
by data source"
This error indicates that you are trying to establish a sockets connection
Maybe I am totally off base, but aren't our client connections to Progress
sockets connections. If not, why do you supply socket connection parameters
in the vantage.pf? It's the end of a loonnngg week and and frustrated. Any
Thanks to all
Jim Stetter
Snow Filtration
