Operation Specifications
Unfortunately, I'm just an engineering grunt and they don't let me have
access to fun stuff like that (probably for good reason!)
We are on 8.0, and from what I understand, reports aren't quite as sharable
because of the customizations we've done, so it probably wouldn't be much
use to you anyway.
Basically, to describe what I can see on the report, as long as your
materials are associated to operations, you just move the material under
the associated op, rather than listing them all at the beginning. And I'm
fairly certain this isn't just an 8.0 kind of thing, though that is when we
made the change.
Sorry I couldn't be more help...maybe someone else out there has a similar
traveler they can share...
Amy O'Malley
Manfacturing Process Engineer
Synovis IS
On May 24 2006, Colette Bishop wrote:
>Amy,
>Would it be possible for you to share your modified job traveler?
>Thanks
>Colette Bishop
>IT Manager
>J. T. Cullen Company Inc.
Thanks for the responses to my initial email. I think it will be a while before we get to 8.0, but I will keep the dropdown options in mind when we get there.
Another thought we had was to set up a part class for specifications and add them at non stock part numbers that we could then set a material requirements on whatever operations that specification was needed on. As part numbers they would have revisions so they could be updated in one place and would carry forward to whatever job ops they were attached too. You could also then do a where used and see all the parts ops that use that specification.
Any thoughts on this approach?
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
Web: http://www.aceprecision.com/
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Won't you go negative in inventory on the dummy part? If your production
control group/person is looking at availability of parts that could be an
issue.
- Alexander
Paul Pachniak
Sent: Wednesday, May 24, 2006 3:05 PM
To: Vantage Group List (E-mail)
Subject: [Vantage] Operation Specifications
get there.
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
Machining Corp.
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda
+database+software&w5=Database+management+software&w6=Database+marketing+soft
ware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketin
g+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> Database mortgage
software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4
=Pda+database+software&w5=Database+management+software&w6=Database+marketing+
software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+s
oftware&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+
database+software&w5=Database+management+software&w6=Database+marketing+softw
are&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufact
g+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> Database marketing
software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&w
4=Pda+database+software&w5=Database+management+software&w6=Database+marketing
+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
This isn't a bad option--definitely preferrable over making your operations
the same as your procedures. We have done this with some documents (other
than our processes) that we use for things like inspection templates or
limit standards. It works pretty well.
For "materials" like these, we set the required quantity to "0.00001
fixed", so they don't show up on the job pick list (has to be at least 0.01
to show) or send requirements for purchase or manufacturing.
Another idea that might be helpful...we've reconfigured our job traveler to
list the "materials" under each operation that uses them, so that would be
more visual on the floor as to what would be needed for that operation.
Amy O'Malley
Manufacturing Process Engineer
Synovis IS
> that specification.
>Paul E. Pachniak
>Accounting Manager
Amy,
Colette Bishop
IT Manager
901 31st Avenue
P.O. Box 311
Fulton, IL 6125
Phone: 815-589-2412 Ext. 314
Fax: 815-589-4018
Email: <mailto:cbishop@jtcullec> cbishop@...
Of Amy OMalley
Sent: Wednesday, May 24, 2006 3:51 PM
Subject: Re: [Vantage] Operation Specifications
operations
(other
0.01
to
be
Amy O'Malley
Synovis IS
and
As
too.
> that specification.
>Paul E. Pachniak
>Accounting Manager
SPONSORED LINKS
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/vantage> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
