Operation Standard
What I am seeing is that the dropdown is populated but I still have to
select which standard I want to use. I would have thought that whatever
is assigned to the resource group would populate automatically and I
wouldn't have to select. Right now I am in the process of updating alot
of old data and I thought I would be able to do a mass replace of
operation/resource group and all of my methods would be updated with the
correct run/setup times. I guess not though
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
More than 100,000 Ion Beam Sputtered filters delivered - extensive
inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
_____
From: Michael McWilliams [mailto:mmcwilliams22@...]
Sent: Tuesday, October 23, 2007 1:50 PM
Subject: [Vantage] Re: Operation Standard
What I have ran into is that if you drag the resource group in from
the Engineering tab in Quote, or Job Entry it will pull the standard.
I have all of my standards set up at the Resource group.
"kam4085" <kmaclennan@...> wrote:
> Is anyone out there using the operation standard option on the
resource
> groups? By reading the help, my understanding is that if you
assign a
> standard to the group and then call out the group on the
operation,
> when a method is entered that calls for that operation, the
standard
> will automatically be populated. I have done this but when I enter
the
> operation in a method I have to manually select the standard. I
guess I
> don't see the point of assigning it to the resource group. Of
course it
> makes more sense to assign it to an operation rather than a
resource
> group since I may have multiple operation that use the same group.
This
> is forcing me to set up new groups for each variation of the
operation.
> Any help would be appreciated.
> Thanks
> Kersten
Is anyone out there using the operation standard option on the resource
groups? By reading the help, my understanding is that if you assign a
standard to the group and then call out the group on the operation,
when a method is entered that calls for that operation, the standard
will automatically be populated. I have done this but when I enter the
operation in a method I have to manually select the standard. I guess I
don't see the point of assigning it to the resource group. Of course it
makes more sense to assign it to an operation rather than a resource
group since I may have multiple operation that use the same group. This
is forcing me to set up new groups for each variation of the operation.
Kersten
resource
assign a
operation,
standard
the
guess I
course it
resource
This
operation.
> Thanks
> Kersten
