Opportunity Dashboard
--- In vantage@yahoogroups.com, Jerry Boyle <jboyle@...> wrote:
> We found this same behavior and traced it to a "quoted" field in the
> QuoteDtl table. This is supposed to be a mirror of the "quoted" field
> in the QuoteHead table but does not always get updated correctly. We
> had quotes where line 1 would show as quoted and line 2 as not quoted
> when the header was marked as quoted. The only fix we have found is
> when we find this, we open the quote, uncheck and check the quoted box
> and it seems to refresh all lines to the correct status.
> On 7/28/2010 1:20 PM, sanfranc415 wrote:
> > Can somebody please explain why some quotes/line numbers are displayed in the Quote/Quoted Tab and others are listed in Quote/Un-Quoted tabs?
> > I don't see this having anything to do with the quote/quoted check box.
> > --sf
Thanks. The only problem is the "Quoted" box is grayed out. Some quotes for no peculiar reason.
--sf
--sf
> --sf
