Optimizing Performance
If you are talking about the vantage\startup.pf file, I don't have a -
b. Could that be the problem??? How do I know what what to set it
at for sure?? Ann Harrell, AMFAB
--- In vantage@y..., "Sgroi, Bart T." <btsgroi@e...> wrote:
> With the memory usage at 40% of the 512 total, does that mean you
have a
> really small -B parameter?
> What is you -B and you blocksize?
> Bart Sgroi
> -----Original Message-----
> From: amfabllc [mailto:amfab@a...]
> Sent: Wednesday, September 25, 2002 10:04 AM
> To: vantage@y...
> Subject: [Vantage] Optimizing Performance
> In the eManufacturing System Administration Guide for Windows NT
> networks, under 'System Maintenance: Performance Tuning - System'
it
> tells specifically what information in NT Performance Monitor to
> check. Under 'Interpreting the Data:', I compared Logical Disk:
> Disk Queue Length & % Disk Time; Memory: Available Bytes &
> Pages/second; and Processor: % Processor Time. All appear to be
> reasonable according to the guidelines listed except 'Pages/sec'.
> The first time I ran it for 1 minute, Pages/Sec = 40.447. The
second
> time I ran it for 15 minutes, Pages/Sec = 68.41. The guidelines
> say "This parameter monitors the number of pages being written
> between physical memory and the paging file. This number should be
> below 20." Any suggestions on if this should be a concern or how
to
> fix? This is on a Compaq 6000, 500 MHz, 512 mb RAM, dual
processor,
> Smart Array Controller, RAID 10, NT4. Vantage: 5.00.329, 2.5 GB,
50
> user. The hard drive is approx. 15GB, with only 2GB remaining.
Task
> manager shows CPU usage average under 10% with occasional spikes to
> approx 80%, MEM usage average 40%. I appreciate all input on or
off-
> line. Thanks! Ann Harrell, AMFAB
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
networks, under 'System Maintenance: Performance Tuning - System' it
The first time I ran it for 1 minute, Pages/Sec = 40.447. The second
below 20." Any suggestions on if this should be a concern or how to
fix? This is on a Compaq 6000, 500 MHz, 512 mb RAM, dual processor,
Smart Array Controller, RAID 10, NT4. Vantage: 5.00.329, 2.5 GB, 50
user. The hard drive is approx. 15GB, with only 2GB remaining. Task
approx 80%, MEM usage average 40%. I appreciate all input on or off-
With the memory usage at 40% of the 512 total, does that mean you have a
Bart Sgroi
Add more ram and increase your -B parameter, NT and progress love RAM.
Patrick
Sent: Wednesday, September 25, 2002 9:04 AM
