Order Book Value Report
I've got a backlog report in Report Builder that has 4 columns for
release months, and a column for remaining. You should be able to
run it for any time in past. Three Rows further categorize the data
by product code grouping.
Five calculated fields have to be edited for the column date ranges.
If anyone interested, email me off list for a copy and further
description.
If a moderator is listening, let us know when we'll have more upload
space.
Lonnie
--- In vantage@y..., "Chris Reed" <chrisr@p...> wrote:
> Hi Shirley
> My idea is for the report to reflect the value of outstanding sales
orders
> at a point in history to assess those book values against current
levels. I
> have the idea that the report should return for the period by
filtering on a
> single date
> If you check out the Vantage canned report >Sales Management>Order
> Management>Reports>Sales Order Backlog, accept the defaults except
uncheck
> the Print Order Release Detail that's pretty much it, but I want
the ability
> to view it retrospectively i.e. what was our order book looking
like six
> months ago.
> Does this help? If not let me know and I'll try a different tack.
> Many thanks
> Chris
> PWSL
> -----Original Message-----
> From: Shirley Graver [mailto:shirleyg@R...]
> Sent: Thursday, January 24, 2002 1:30 PM
> To: vantage@y...
> Subject: RE: [Vantage] Order Book Value Report
> Chris,
> I've taken a quick look, my first impression is to forget about
Report
> Builder. This can only be done in crystal using odbc. It looks
like its
> something that I'd find useful also. A couple of questions though,
can you
> give me a little more detail on what you're looking for, how it
would be
> used and the kinds of time periods you have in mind. Anything else
that you
> have in mind as far as how such a report would be used would help.
> Shirley
> From: Chris Reed [mailto:chrisr@p...]
> Sent: Tuesday, January 22, 2002 9:18 AM
> To: vantage@y...
> Subject: Re: [Vantage] Order Book Value Report
> Does anyone have a Sales Order Value report, similar to the
canned Sale
> Order Backlog report they're prepared to share?
> I'm looking for a summarised period on period report for
comparisons.
> Currently running v4.
> Thanks
> Regards Chris Reed
> Professional Welding Services Limited
> Yahoo! Groups Sponsor
> ADVERTISEMENT
must
> have already linked your email address to a yahoo id to enable
access. )
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
must have
Builder and
http://docs.yahoo.com/info/terms/
Does anyone have a Sales Order Value report, similar to the canned Sale
I'm looking for a summarised period on period report for comparisons.
Regards Chris Reed
Go to www.ktcorp.com/vantage
We put together an Access database that has several different backlog
reports. One is a summary by customer and Product Group. You would need
the ODBC Drive for it to work.
Jeremy
Regards Chris Reed
Chris,
I've taken a quick look, my first impression is to forget about Report
Builder. This can only be done in crystal using odbc. It looks like its
something that I'd find useful also. A couple of questions though, can you
give me a little more detail on what you're looking for, how it would be
used and the kinds of time periods you have in mind. Anything else that you
Shirley
Regards Chris Reed
ADVERTISEMENT
Bookings record only quantity and dollar changes not date changes.
Order change log records all changes but in a table report builder/crystal
can not unscramble. Maybe some custom code could pluck out the date changes
but it would not be pretty.
So if your trying to see the effect of a blanket type sales order that
simply gets moved out of this month meaning your bookings for the month went
down. Vantage does not log this.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
Sent: Thursday, January 24, 2002 7:30 AM
Chris,
Shirley
Regards Chris Reed
ADVERTISEMENT
Hi Shirley
My idea is for the report to reflect the value of outstanding sales orders
at a point in history to assess those book values against current levels. I
have the idea that the report should return for the period by filtering on a
single date
Management>Reports>Sales Order Backlog, accept the defaults except uncheck
the Print Order Release Detail that's pretty much it, but I want the ability
to view it retrospectively i.e. what was our order book looking like six
months ago.
Many thanks
Chris
PWSL
Chris,
Shirley
Regards Chris Reed
ADVERTISEMENT
Chris, [offline]
Here's our (what we call) Bookings Report. I don't know if it's at all what you're looking for or not. It's written for Vantage 5.0, so you may need to modify some fields for 4.0. I don't know how things have changed field-wize.
Troy
----- Original Message -----
Sent: Thursday, January 24, 2002 9:53 AM
Hi Shirley
single date
months ago.
Many thanks
Chris
PWSL
Chris,
Shirley
Regards Chris Reed
ADVERTISEMENT
ADVERTISEMENT
Opps. I thought I was offline. I'm glad I didn't say anything embarrassing...
Sent: Thursday, January 24, 2002 11:12 AM
Chris, [offline]
Troy
Hi Shirley
single date
months ago.
Many thanks
Chris
PWSL
Chris,
Shirley
Regards Chris Reed
ADVERTISEMENT
ADVERTISEMENT
