OrderHed.Mulref what sets field
It looks like it is set to true if there is a change in the
OrderRel.Reference field. They set a variable = OrderRel.Reference then
later check to see if it is still equal. If it is not MulRef = yes. I don't
know exactly what would change the field, but hopefully this gets you going
in the right direction.
Mark Kohring
Delta Centrifugal Corp.
Sent: Wednesday, July 18, 2001 11:58 AM
To: Vantage Onelist (E-mail)
Subject: [Vantage] OrderHed.Mulref what sets field
When you view an Order Acknowledgement, and look in the Vntgwork folder, the
OrderHed.DBF has this field in it. It is being used in a Crystal Report,
Custom Order Acknowledgement. This field is a True or False.
What I want to know is what field(s) does Vantage check to determine if it
is True or False setting for this field - OrderHed.Mulref.
Thanks for the help.
Nancy Dunn
Winco Industries
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Nancy Dunn
Winco Industries
