OrderHed.SalesRepList in 9.05.700
Thanks on this!  Even though your post is from almost a year ago, it's fixed my BAQ problem!   Laraine   --- In vantage@yahoogroups.com, <vantage@...> wrote: Use 4 four ~~~~. Ie. IF (Num-entries(OrderHed.SalesRepList , "~~~~")>=1)
then
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of
b_ordway
Sent: Friday, September 07, 2012 3:23 PM
Subject: [Vantage] OrderHed.SalesRepList in 9.05.700
Anybody running into problems in 9.05.7 with calculated fields using
Num-entries and Entry to separate the OrderHed.SalesRepList?
I've used this in previous versions but no luck so far in 9.05.700:
SalesRep1:
IF (Num-entries(OrderHed.SalesRepList , "~~")>=1) then
Entry(1, OrderHed.SalesRepList , "~~") else ""
SalesRep2:
IF (Num-entries(OrderHed.SalesRepList , "~~")>=2) then
Entry(2, OrderHed.SalesRepList , "~~") else ""
The syntax passes in the BAQ designer - but I get this error when I test:
"Table: , Level:, Type: , RowID: , Text: Business Query Execution error.
Please contact your System Administrator."
Anybody running into problems in 9.05.7 with calculated fields using Num-entries and Entry to separate the OrderHed.SalesRepList?
SalesRep1:
SalesRep2:
The syntax passes in the BAQ designer - but I get this error when I test: "Table: , Level:, Type: , RowID: , Text: Business Query Execution error. Please contact your System Administrator."
then
b_ordway
SalesRep1:
SalesRep2:
Thanks, this worked in the query I needed it to.
Seems strange, I guess I'll have to take a fresh look.
I had just tested it again in a simpler query - still using "~~"
In the simpler query "~~" worked?
> then
> b_ordway
> SalesRep1:
> SalesRep2:
> Thanks
