OT: 2D Barcodes
http://www.tcpdf.org/examples.php
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Tuesday, June 16, 2015 3:08 PM
Subject: RE: [Vantage] RE: OT: 2D Barcodes
Which barcode library did you end up using specifically if you recall?  This seems like a perfect solution for my needs.
Thanks!
Sent: Tuesday, June 16, 2015 1:19 PM
Subject: [Vantage] RE: OT: 2D Barcodes
Disclaimer this is a hinky hack but it works and has worked for us flawless for years.
 If you want to use 2D on say a crystal report. Setup a PHP webserver (free) with 2D barcode generation libraries (free) and pass url parameters as variables from crystal image formula to generate a dynamic 2D barcode image in crystal. It took me about 2 hours to setup start to finish and that was with trying to feel out the best way to make it work.
This formula is used as a PDF417
"http://our.barcode.webhost.local/?code=PDF417,4&data=" + {JobMtl.PartNum} + "~" + ToText({JobMtl.RequiredQty}) + "~" + {JobMtl.WarehouseCode} + "~" + {JobOpDtl.ResourceID} + "~" + {JobOpDtl.JobNum}
Joshua Giese
CIO
Sent: Tuesday, June 16, 2015 1:12 PM
We have a customer that requires them on product packaging.   DataMatrix something or other.  We use BarTender, standalone – not via E10 because that’s broken until 10.1.  Works fine for the customer.
-Todd C.
Sent: Tuesday, June 16, 2015 12:06 PM
Subject: [Vantage] OT: 2D Barcodes
Do you use 2D barcodes, if so, do you use anyone other than IDAutomation?
Miguel A. Santillan
ERP Analyst
Posted by: Joshua Giese <jgiese@...>
Miguel A. Santillan
ERP Analyst
-Todd C.
Miguel A. Santillan
ERP Analyst
Joshua Giese
CIO
-Todd C.
Miguel A. Santillan
ERP Analyst
What's wrong with E10 barcodes?
Regards,
Tom Christie | Information Technology & Human Resources Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Tuesday, June 16, 2015 11:12 AM
We have a customer that requires them on product packaging. DataMatrix something or other. We use BarTender, standalone - not via E10 because that's broken until 10.1. Works fine for the customer.
-Todd C.
Miguel A. Santillan
ERP Analyst
Todd,
I am successfully using BarTender under 10.0.700.4.  I am even hosted with EMS and it is working from the Data Directive Auto Print to Commander acting on the bt file.  Epicor does have a bundle of patches for BarTender that need to be applied.
Scott
-Todd C.
Miguel A. Santillan
ERP Analyst
Our basic problem was the file that Commander picks up was missing the printer name.  I could manually edit it in and it worked but the part that generated the BT file was omitting the printer.  I have a patch for it but by the time I got it it was all done and easier to just keep printing from a data form filled in using Print Station.   We have put so many one-off patches on I am no longer sure what version/flavor we are running and really hesitant to do any more unless drop dead urgent.
-Todd
Sent: Tuesday, June 16, 2015 1:33 PM
Todd,
Scott
-Todd C.
Miguel A. Santillan
ERP Analyst
Thanks!
Joshua Giese
CIO
-Todd C.
Miguel A. Santillan
ERP Analyst
