OT: Access tables - setting value of a new record by looking up
Thanks for the advice - Unfortunately I need to retain most of the
original semi-sequential numbering systems, as they are being used to
provide serial numbers, drawing and various other record, so I'll try
the DMax approach.
Where I can, I intend to simplify things by dropping the old numbering
systems (often alpha-numeric composite strings) for a simplified numeric
system!
Best Regards,
Paul Whittle
Of Mark Wonsil
Sent: 20 June 2007 14:58
Subject: RE: [Vantage] OT: Access tables - setting value of a new record
by looking up the value in another table
> Have you considered using two different keys? When converting data
from
> an old system to Access I've often set up two keys. The old key which
> is just an indexed field and then a new key that is the autonumbered
> primary key. It keeps me from having to manually control a sequencial
> key.
I agree with Lon. But if you really need to manage the sequential key,
lookup
up the domain function DMax. It will return the highest value in a
column for
a given domain (in this case a table).
Mark W.
Click here
<https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
cHamQ+aImTboPCR72D4roNxkpMmBjNKqfZAhmtVAt9CuFfG33Kr+KZbQpsjW0vvCnseIHKJG
n+37UOipLZ29vmsFyzPVhOMsi5Hd8kyb0M!Eb7OhLqlPEJH+Mkn9qdZ82NEjZn+ZIkaVq6ay
GAfZwswZDoU8ahx5p8BC!PV0QeXSl+LmMraunYW3> to report this email as spam.
Help!
I am somewhat inexperienced in doing much with Access other than using
it to querying data sets to create multitudes of reports, and I am
trying to convert a bunch of databases from Lotus Approach to MS Access
2003. Originally I thought I would be able to use Autonumber to create
the sequential numbering of the database entries, but subsequently I
have realised that the historical format of the key data has changed
over the years, and we also have the odd gap in the numbering sequence,
so nothing totally sequential will work!.
I can foresee that the solution is to have a separate table holding the
value of the last record, and when creating a new record, to read this
table, add 1 to it, write this into the appropriate field of the new
record, and then to update the separate table with the revised number.
This has the advantage of being able to import the old data as it is,
and to ensure that all new records are truly sequential.
It would seem to me that the default field value should therefore be the
reference table field value + 1, but I can't make this work, and
similarly I can't fathom the syntax of using set value as an event to
write the number back.
Can any of you Access gurus point me in the right direction? I think I
am missing something very fundamental!
Kind Regards,
Paul Whittle
Business Process Manager
Jiskoot Ltd
Goods Station Road
Tunbridge Wells
Kent TN1 2DJ
UK
Switchboard: +44 (0) 1892 518000
Direct: +44 (0) 1892 779975
Fax: +44 (0) 1892 518100
www.jiskoot.com <http://www.jiskoot.com/>
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
This email transmission is confidential and intended solely for the person or organisation to whom it is addressed. If you are not the intended recipient,you must not copy, distribute or disseminate the information, or take any action in reliance on it. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of an organisation or employer. If you have received this message in error, please do not open any attachment, but notify the sender(above) and delete this message from your system. Please rely on your own virus check; no responsibility is taken by the sender for any damage arising out of any bug or virus infection.
Jiskoot Limited
Reg. Office: 2 Bloomsbury Street, London WC1B 3ST
Reg. No.: 1834943 England
Have you considered using two different keys? When converting data from
key.
Lon A. Wiksell
ROM Corporation
816-318-8000
Of Paul Whittle
Sent: Wednesday, June 20, 2007 8:23 AM
Subject: [Vantage] OT: Access tables - setting value of a new record by
Help!
Kind Regards,
Paul Whittle
Jiskoot Ltd
Goods Station Road
Tunbridge Wells
Kent TN1 2DJ
UK
www.jiskoot.com <http://www.jiskoot.com/ <http://www.jiskoot.com/> >
www.blackspider.com
infection.
Jiskoot Limited
> key.
I agree with Lon. But if you really need to manage the sequential key, lookup
up the domain function DMax. It will return the highest value in a column for
Mark W.
