OT: Barcode Help
Escape was a good idea, but for some reason %A did nothing. I'm very
confused by my scanner, but through trial and error I figured out
that $O works as the Escape key.
My problem appears to be solved, but if anyone can shed some light on
why my scanner doesn't seem to follow the list of codes I'd
appreciate it. It does seem to match for $I = TAB and $M = Enter,
but $V seems to be F1.
They are WelchAllyn scanners.
Brian Stenglein
Clow Stamping Company
--- In vantage@yahoogroups.com, "Butch Menge" <bmenge@...> wrote:
> Maybe you can use the Esc key (%A) to close the box.
> Butch
Behalf
> Of Brian Stenglein
> Sent: Friday, December 29, 2006 1:19 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] OT: Barcode Help
> We have a customer that has us enter ASN details on their web-site.
I
> created a report with barcodes that will 1. Open the "Find" dialog.
> (Ctrl+F). Enter the PO#, Hit Enter to do the search, then Tab to
the
> Cancel button and hit Enter to close the find Dialog. 2. Then there
is
> another Barcode that they scan to tab over to the Qty field and
enter
> the Qty and begin the process again. This works fine with IE6.
> I tested this with IE7 and found that the Find dialog no longer has
the
> cancel button, so my barcode won't close the dialog. The only way I
> can think of to close it would be the shortcut Alt+F4. I'm having
> trouble getting that to work. I found a document on this list form
> Jeff Jaske that says Alt would be %D and F4 would be $D so I added
to
> my barcode %D$D but that is not working.
> Any ideas?
> Happy New Year everyone!
> Brian Stenglein
> Clow Stamping Co.
We have a customer that has us enter ASN details on their web-site. I
(Ctrl+F). Enter the PO#, Hit Enter to do the search, then Tab to the
Cancel button and hit Enter to close the find Dialog. 2. Then there is
another Barcode that they scan to tab over to the Qty field and enter
I tested this with IE7 and found that the Find dialog no longer has the
Jeff Jaske that says Alt would be %D and F4 would be $D so I added to
Any ideas?
Brian Stenglein
Clow Stamping Co.
Butch
Of Brian Stenglein
Any ideas?
Brian Stenglein
Clow Stamping Co.
Happy New Year to Every one
John Mansfield
General Sheet Metal
