OT: Browser Hijack
First you might need to use the ATTRIB command to remove the System, Hidden,
and Readonly flags
attrib -s -h -r spyware.dll
attrib does accept wildcards...so attrib -s -h -r *.dll works too.
When dealing with the "in use" or "access is denied" issue, I write a batch
file that loops on deleting the executable.
:top
del spyware.dll
goto top
Then I go to the Task Manager and kill the process. I've seen processes
relaunch themselves on exit - but there is a window of opportunity that the
tight batch file loop takes advantage of.
To start in Safe Mode tap the F8 key just before and during the Window's
Startup Splash. If done correctly, you will get a text based selection
screen - Safe Mode is one of the options. Use the cursor keys to pick the
option you want and press Enter. If the system booted normally - then you
missed with the F8 tap. Reboot and keep trying.
Since you are using Windows 2000 - see if you can find an XP system and copy
the msconfig program to the corresponding folder on the 2000 box - ie.
system32 to system32.
If you do not have XP at your disposal contact me off line or go to this
link I found via Google.
http://www.perfectdrivers.com/howto/msconfig.html
Good Luck - Ho Ho Ho
Charles
cpaluska@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, December 22, 2004 4:55 PM
Subject: RE: [Vantage] OT: Browser Hijack
> It is not CWschredder. The OS is Win2K, Norton doesn't find anything,
> spybot doesn't find anything. SpySubtract finds stuff but it reinstalls
> itself when you reboot. How do I boot in safe mode? I found some suspect
> files but I can't delete them, they are either in use or access is denied.
> Mitchell Kirby
> Riten Industries, Inc.
> 740-333-8719 Direct
> 800-338-0027 Sales
> 800-338-0717 FAX
> -----Original Message-----
> From: Charles Paluska - HPN [mailto:cpaluska@...]
> Sent: Wednesday, December 22, 2004 4:02 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] OT: Browser Hijack
> What OS are you running ?
> What virus software are your using ?
> If possible, remove any "strange" process from starting up using
MSCONFIG -
> available on everything but NT & W2K.
> (you can add the xp version of msconfig to W2K and it will work.)
> Check what processes are running and kill the ones that seem out of place.
> Track down the strange executables and rename them ( I usually replace the
> last character with a hyphen i.e. spyware.dll => spyware.dl-).
> You might have to boot in Safe Mode or Command mode.
> Worst case is removing the drive and added it to another system as a slave
> so that you can rename the stubborn buggers.
> I use an external USB drive for this type of problem.
> Good Luck & Merry Christmas
> Charles
> From: "Paul Lipham" <pml@...>
> Sent: Wednesday, December 22, 2004 3:32 PM
> > Try CWshredder, you can get it from www.majorgeeks.com. Also, search
> their
> > site and see if there is any information on coderz
> > Paul L.
> > From: Mitchell Kirby [mailto:m.kirby@...]
> > Sent: Wednesday, December 22, 2004 1:43 PM
> > To: Vantage (E-mail)
> > Subject: [Vantage] OT: Browser Hijack
> > Does coderz ring a bell with anyone? I have a laptop that has a
> hijacked
> > browser to the point that it is almost unusable. Of course it has no
> > backups and the information on it is mission critical. It seems to be
> > hiding on the machine and reinstalls itself on boot up. Spybot
doesn't
> > touch it.
> > Mitchell Kirby
> > 740-333-8719 Direct
> > 800-338-0027 Sales
> > 800-338-0717 FAX
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Sponsor
> > Get unlimited calls to
> > U.S./Canada
> > Yahoo! Groups Links
> > a.. To visit your group on the web, go to:
> > b.. To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
and
> > Yahoo! Groups Links
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
> Yahoo! Groups Links
Does coderz ring a bell with anyone? I have a laptop that has a hijacked
hiding on the machine and reinstalls itself on boot up. Spybot doesn't
touch it.
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Mitchell
Download and run the following:
All are free
Adaware SE (like spybot)
Hijackthis
CWShredder
This is of course still no guarantee that your PC will be cleaned.
Rich
> touch it.
> Mitchell Kirby
> 740-333-8719 Direct
> 800-338-0027 Sales
> 800-338-0717 FAX
Mitchell
Sorry I forgot.....................
Be careful with Hijackthis.
It is a program that can make your PC unusable
Rich Shafer wrote:
> Mitchell
> All are free
> Hijackthis
> CWShredder
> Rich
> hijacked
> > touch it.
> > Mitchell Kirby
> > 740-333-8719 Direct
> > 800-338-0027 Sales
> > 800-338-0717 FAX
> and Crystal Reports and other 'goodies', please goto:
> *Yahoo! Groups Sponsor*
> <http://us.ard.yahoo.com/SIG=129tmio2e/M=324658.5816620.6854924.3001176/D=groups/S=1705007183:HM/EXP=1103832120/A=2343726/R=0/SIG=12i7fjor5/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1103745720627343>
> U.S./Canada
> <http://us.ard.yahoo.com/SIG=129tmio2e/M=324658.5816620.6854924.3001176/D=groups/S=1705007183:HM/EXP=1103832120/A=2343726/R=1/SIG=12i7fjor5/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1103745720627343>
> *Yahoo! Groups Links*
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
> __________ NOD32 1.896 (20041015) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.nod32.com
I have checked the CA eTrust PestPatrol database and this does not show up. Do you have any other names for it? Or perhaps by checking the system32 folder and sroting by date you might see a bunch of recent .dll or .exe files with the same date/time that are about the time the problem started. Send a few of these, if any, and I can check the database for them as well incase CA calls it something else. Or try:
http://www3.ca.com/securityadvisor/pest/browse.aspx to look it up yourself. They also offer a "trial" scan which might help if you can get the infected PC to connect to CA.
Otherwise some steps I have used for cleaning infected PCs are:
1. Disconnect from the network and boot in safe mode.
2. In explorer select the C: drive and search for all files mondified after the last known "good" date.
3. When you see bunches of modified files all at about the same time/date change their extensions to 'x' as the alst letter - just in case it is a good file. .dll becomes .dlx etc...
4. Just incase check task manager for running processes that look odd and end them if you can
5. Check the Program Files folder for new folders and programs
6. Search Regedit for "start" (you'll get a LOT of false hits) and examine for strange programs being started
7. Sometimes files can not be deleted even in safe mode so boot to safe mode command prompt and use the good old DOS commands to delete files and folders
8. Download hijackthis and run it to check various running processes and registry entries. Be very suspicious of BHO items.
I have yet to have had a PC I could not manually clean even though some ahve taken as much as half a day of chasing sytartup processes that repopulate the files I have already deleted. As much as a PITA that it is sometimes it is sort of interesting - like figuring out a new level in Doom or Myst.
-Todd C.
touch it.
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
<http://us.ard.yahoo.com/SIG=129g3nl0a/M=324658.5816620.6854924.3001176/D=groups/S=1705007183:HM/EXP=1103830969/A=2343726/R=0/SIG=12iq0phsk/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1103744569834653> <http://us.ard.yahoo.com/SIG=129g3nl0a/M=324658.5816620.6854924.3001176/D=groups/S=1705007183:HM/EXP=1103830969/A=2343726/R=1/SIG=12iq0phsk/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1103744569834653>
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=1103744569834653>
<http://us.adserver.yahoo.com/l?M=324658.5816620.6854924.3001176/D=groups/S=:HM/A=2343726/rand=551637013>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
how about running Hijack this and then erasing from within the registry?
touch it.
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Yahoo! Groups Links
Try CWshredder, you can get it from www.majorgeeks.com. Also, search their
Paul L.
touch it.
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
U.S./Canada
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Also, check PCHell. They usually post fixes for the latest worm/hijack
items.
Lydia
Sent: Wednesday, December 22, 2004 12:33 PM
Paul L.
touch it.
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
U.S./Canada
Yahoo! Groups Links
Yahoo! Groups Links
If possible, remove any "strange" process from starting up using MSCONFIG -
Charles
their
> Paul L.
hijacked
> touch it.
> Mitchell Kirby
> 740-333-8719 Direct
> 800-338-0027 Sales
> 800-338-0717 FAX
and
> U.S./Canada
> Yahoo! Groups Links
Service.
> Yahoo! Groups Links
Mitchell Kirby
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Charles
their
> Paul L.
hijacked
> touch it.
> Mitchell Kirby
> 740-333-8719 Direct
> 800-338-0027 Sales
> 800-338-0717 FAX
and
> U.S./Canada
> Yahoo! Groups Links
Service.
> Yahoo! Groups Links
Yahoo! Groups Links
