OT:Cisco 2610 PPP (Additional Info)
I thought that this might help diagnose my problem.
Jeremy
HTSH#show version
Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 24-May-05 14:01 by ssearch
Image text-base: 0x80008098, data-base: 0x80CD8A7C
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
HTSH uptime is 1 hour, 28 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.123-15.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory.
Processor board ID JAD04400RWN (2521382744)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
HTSH#show tech-support
------------------ show version ------------------
HTSH uptime is 1 hour, 29 minutes
Bridging software.
------------------ show running-config ------------------
Building configuration...
Current configuration : 900 bytes
version 12.3
service config
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname HTSH
boot-start-marker
boot-end-marker
no logging console
enable secret 5 <removed>
enable password <removed>
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Ethernet0/0
description connected to EthernetLAN
ip address 192.168.1.3 255.255.255.0
half-duplex
interface Serial0/0
description connected to HTSS
ip address 10.20.12.1 255.255.255.0
encapsulation ppp
service-module t1 remote-alarm-enable
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip http server
ip classless
snmp-server community <removed> RO
banner login ^CCThis is Router HTSH ^C
line con 0
exec-timeout 0 0
password <removed>
login
line aux 0
line vty 0 4
password <removed>
login
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
5660/6000 Autoinstall
10748/12000 Setup
4424/6000 DNS Snoop
9388/12000 Init
5460/6000 RADIUS INITCONFIG
9488/12000 Exec
11540/12000 BootP Resolver
11396/12000 Router Init
10132/12000 DHCP Autoinstall
9504/12000 HTTP CP
35292/36000 TCP Command
10256/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 25232 7904/9000 Network interfaces
2 0 9000/9000 Timebase Reference Interrupt
3 0 9000/9000 PA Management Int Handler
6 1602 8880/9000 16552 Con/Aux Interrupt
7 1334111 8920/9000 MPC860 TIMER INTERRUPT
------------------ show interfaces ------------------
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 0003.e3c8.fb20 (bia 0003.e3c8.fb20)
Description: connected to EthernetLAN
Internet address is 192.168.1.3/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:40, output 00:00:09, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
9606 packets input, 679036 bytes, 0 no buffer
Received 8590 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 input packets with dribble condition detected
1741 packets output, 208546 bytes, 0 underruns
14 output errors, 0 collisions, 4 interface resets
0 babbles, 0 late collision, 0 deferred
14 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Description: connected to HTSS
Internet address is 10.20.12.1/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Open
Open: CDPCP, IPCP, loopback not set
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 01:26:33
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
1897 packets input, 97866 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1944 packets output, 100554 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
1 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
------------------ show controllers ------------------
Interface Ethernet0/0
Hardware is AMD Presidio
ADDR: 8157EFC8, FASTSEND: 80020FAC, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 11
LADRF=0x0020 0x0100 0x0000 0x0000
CSR0 =0x00000072, CSR3 =0x00001044, CSR4 =0x0000491D, CSR15 =0x00000000
CSR80 =0x0000D900, CSR114=0x00000000, CRDA =0x03D17630, CXDA =0x03D17820
BCR9 =0x00000000 (half-duplex)
HW filtering information:
Promiscuous Mode Disabled, PHY Addr Enabled, Broadcast Addr Enabled
PHY Addr=0003.E3C8.FB20, Multicast Filter=0x0020 0x0100 0x0000 0x0000
amdp2_instance=0x8155E6D0, registers=0x40000000, ib=0x3D17540
rx ring entries=32, tx ring entries=64
rxring=0x3D175A0, rxr shadow=0x8155E81C, rx_head=9, rx_tail=0
txring=0x3D177E0, txr shadow=0x81580644, tx_head=4, tx_tail=4, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
0x57: 0 0100.5e00.0009 0000.0000.0000 0
0xC0: 0 0100.0ccc.cccc 0000.0000.0000 0
spurious_idon=0, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=14
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=0, need_af_check=0
tx_limited=0(64)
Interface Serial0/0
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x815829C8, driver data structure at 0x8158A75C
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00008000
Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
[PAODR]=0x0000, [PADAT]=0xE7FF
Port B [PBDIR]=0x0180F, [PBPAR]=0x0000E
[PBODR]=0x00000, [PBDAT]=0x3E77D
Port C [PCDIR]=0x00C, [PCPAR]=0x000
[PCSO]=0x020, [PCDAT]=0xFC0, [PCINT]=0x00F
Receive Ring
rmd(680126B0): status 9000 length 12 address 3D46924
rmd(680126B8): status 9000 length 12 address 3D47624
rmd(680126C0): status 9000 length 12 address 3D47CA4
rmd(680126C8): status 9000 length 3A address 3D462A4
rmd(680126D0): status 9000 length 12 address 3D3E0A4
rmd(680126D8): status 9000 length 12 address 3D3E724
rmd(680126E0): status 9000 length 12 address 3D3EDA4
rmd(680126E8): status 9000 length 12 address 3D3F424
rmd(680126F0): status 9000 length 12 address 3D3FAA4
rmd(680126F8): status 9000 length 3A address 3D40124
rmd(68012700): status 9000 length 12 address 3D407A4
rmd(68012708): status 9000 length 12 address 3D40E24
rmd(68012710): status 9000 length 150 address 3D414A4
rmd(68012718): status 9000 length 12 address 3D41B24
rmd(68012720): status 9000 length 12 address 3D421A4
rmd(68012728): status 9000 length 12 address 3D42824
rmd(68012730): status 9000 length 12 address 3D42EA4
rmd(68012738): status 9000 length 3A address 3D43524
rmd(68012740): status 9000 length 12 address 3D43BA4
rmd(68012748): status 9000 length 12 address 3D44224
rmd(68012750): status 9000 length 12 address 3D448A4
rmd(68012758): status 9000 length 12 address 3D44F24
rmd(68012760): status 9000 length 12 address 3D455A4
rmd(68012768): status B000 length 3A address 3D45C24
Transmit Ring
tmd(68012770): status 5C00 length 38 address 3D547D4
tmd(68012778): status 5C00 length 10 address 3C014D4
tmd(68012780): status 5C00 length 10 address 3D448A4
tmd(68012788): status 5C00 length 10 address 3C01614
tmd(68012790): status 5C00 length 14E address 3D617F4
tmd(68012798): status 5C00 length 10 address 3D455A4
tmd(680127A0): status 5C00 length 10 address 3C00C14
tmd(680127A8): status 5C00 length 10 address 3D46FA4
tmd(680127B0): status 5C00 length 38 address 3D53834
tmd(680127B8): status 5C00 length 38 address 3D55454
tmd(680127C0): status 5C00 length 10 address 3D52574
tmd(680127C8): status 5C00 length 10 address 3D414A4
tmd(680127D0): status 5C00 length 10 address 3C00494
tmd(680127D8): status 5C00 length 10 address 3D42824
tmd(680127E0): status 5C00 length 10 address 3C01394
tmd(680127E8): status 7C00 length 10 address 3D43524
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0x68013C00)
Rx BD Base [RBASE]=0x26B0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x2770, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x26B8
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x27B8
SCC HDLC PARAMETER RAM (at 0x68013C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1524
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=63639
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
0 aborted short frames
------------------ show user ------------------
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:12
Interface User Mode Idle Peer Address
Se0/0 Sync PPP 01:26:32 10.20.12.3
------------------ show file systems ------------------
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
29688 26677 nvram rw nvram:
- - opaque rw null:
- - opaque ro xmodem:
- - opaque ro ymodem:
- - network rw tftp:
* 16252924 8556028 flash rw flash:
- - network rw rcp:
- - network rw ftp:
- - opaque ro cns:
------------------ dir nvram: ------------------
Directory of nvram:/
27 -rw- 884 <no date> startup-config
28 ---- 27 <no date> private-config
1 -rw- 0 <no date> ifIndex-table
2 ---- 12 <no date> persistent-data
29688 bytes total (26677 bytes free)
------------------ show flash: all ------------------
Partition Size Used Free Bank-Size State Copy Mode
1 15871K 7516K 8355K 8192K Read/Write Direct
System flash directory:
File Length Name/status
addr fcksum ccksum
1 7696832 c2600-i-mz.123-15.bin
0x40 0xF911 0xF911
[7696896 bytes used, 8556028 available, 16252924 total]
Chip Bank Code Size Name
1 1 01AD 2048KB AMD 29F016
2 1 01AD 2048KB AMD 29F016
3 1 01AD 2048KB AMD 29F016
4 1 01AD 2048KB AMD 29F016
1 2 01AD 2048KB AMD 29F016
2 2 01AD 2048KB AMD 29F016
3 2 01AD 2048KB AMD 29F016
4 2 01AD 2048KB AMD 29F016
------------------ show memory statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 8147B380 41823084 3664416 38158668 38063824 37493584
I/O 3C00000 4194304 1533112 2661192 2661192 2661148
------------------ show process memory ------------------
Total: 41823084, Used: 3664752, Free: 38158332
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 146704 10892 2598044 0 0 *Init*
0 0 920 264468 920 0 0 *Sched*
0 0 8388492 3514568 131616 170064 0 *Dead*
1 0 0 0 6892 0 0 Chunk Manager
2 0 188 188 3892 0 0 Load Meter
3 0 194276 190852 16360 0 0 Exec
4 0 0 0 6892 0 0 Check heaps
5 0 0 0 6892 0 0 Pool Manager
6 0 188 188 6892 0 0 Timers
7 0 188 188 6892 0 0 Serial Backgroun
8 0 188 188 6892 0 0 AAA high-capacit
9 0 188 188 6892 0 0 Environmental mo
10 0 76 0 6968 0 0 ARP Input
11 0 0 0 6892 0 0 HC Counter Timer
12 0 188 188 6892 0 0 DDR Timers
13 0 5348 1212 11028 0 0 Entity MIB API
14 0 0 0 6892 0 0 SERIAL A'detect
15 0 188 188 6892 0 0 GraphIt
16 0 188 188 12892 0 0 Dialer event
17 0 188 188 6892 0 0 SMART
18 0 0 0 6892 0 0 Critical Bkgnd
19 0 20940 0 13156 0 0 Net Background
20 0 188 188 12892 0 0 Logger
21 0 39284 460 7028 0 0 TTY Background
22 0 0 0 9892 0 0 Per-Second Jobs
23 0 188 188 6892 0 0 SM Monitor
24 0 0 0 3892 0 0 dev_device_inser
25 0 0 0 3892 0 0 dev_device_remov
26 0 0 0 6892 0 0 Net Input
27 0 188 188 6892 0 0 Compute load avg
28 0 0 0 6892 0 0 Per-minute Jobs
29 0 0 0 6892 0 0 Service-module a
30 0 188 188 6892 0 0 AAA Server
31 0 0 0 6892 0 0 AAA ACCT Proc
32 0 0 0 6892 0 0 ACCT Periodic Pr
33 0 0 0 6892 0 0 AAA_SERVER_DEADT
34 0 188 188 6892 0 0 AAA Dictionary R
35 0 13144 0 12968 0 0 IP Input
36 0 0 0 6892 0 0 ICMP event handl
37 0 17820 15516 9124 0 0 CDP Protocol
38 0 376 376 12892 0 0 PPP Hooks
39 0 0 0 6892 0 0 X.25 Encaps Mana
40 0 0 13068 12892 0 0 TCP Timer
41 0 37212 0 12892 0 0 TCP Protocols
42 0 0 0 6892 0 0 Socket Timers
43 0 210904 110616 18712 0 0 HTTP CORE
44 0 1336 712 13788 0 0 PPP IP Route
45 0 188 188 12892 0 0 PPP IPCP
46 0 764 368 10520 0 0 IP Background
47 0 152 0 10044 0 0 IP RIB Update
48 0 188 188 9892 0 0 Adj Manager
49 0 74532 1088 73444 0 0 CEF process
50 0 0 0 6892 0 0 Asy FS Helper
51 0 0 0 6892 0 0 RARP Input
52 0 32656 3028 22736 0 0 DHCPD Receive
53 0 0 0 6892 0 0 IP Cache Ager
54 0 0 0 24892 0 0 COPS
55 0 188 188 6892 0 0 PPP Bind
56 0 0 0 6892 0 0 PAD InCall
57 0 188 188 12892 0 0 X.25 Background
58 0 188 188 6892 0 0 CRM_CALL_UPDATE_
59 0 188 188 6892 0 0 LOCAL AAA
60 0 188 188 6892 0 0 ENABLE AAA
61 0 188 188 6892 0 0 LINE AAA
62 0 2072 188 8776 0 0 TPLUS
63 0 0 0 6892 0 0 Key chain liveke
64 0 0 0 12892 0 0 PPP manager
65 0 188 188 6892 0 0 AAA SEND STOP EV
66 0 0 0 6892 0 0 Syslog Traps
67 0 0 0 6892 0 0 DHCPD Timer
68 0 121444 456 133880 0 0 PPP Events
69 0 348 740 9968 0 0 DHCP Client
71 0 152 0 7044 0 0 CEF Scanner
72 0 188 0 7080 0 0 DHCPD Database
73 0 0 0 6892 0 0 Multilink PPP
74 0 0 0 6908 0 0 SNMP Timers
75 0 15704 0 19384 0 0 RIP Router
76 0 0 28124 6892 0 0 RIP Send
77 0 27852 0 6892 0 0 RIP Timers
78 0 852 0 13776 0 0 IP SNMP
79 0 0 0 12892 0 0 PDU DISPATCHER
80 0 1596 1596 12892 0 0 SNMP ENGINE
81 0 0 0 12892 0 0 SNMP ConfCopyPro
82 0 0 0 12892 0 0 SNMP Traps
3663792 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 1%/0%; one minute: 3%; five minutes: 1%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 4 1052 3 0.00% 0.00% 0.00% 0 Load Meter
3 2726 754 3615 0.79% 2.60% 0.78% 0 Exec
4 2223 541 4109 0.00% 0.04% 0.00% 0 Check heaps
5 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 3 0 0.00% 0.00% 0.00% 0 Serial Backgroun
8 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
9 0 177 0 0.00% 0.00% 0.00% 0 Environmental mo
10 5218 7580 688 0.00% 0.00% 0.00% 0 ARP Input
11 0 1 0 0.00% 0.00% 0.00% 0 HC Counter Timer
12 4 3 1333 0.00% 0.00% 0.00% 0 DDR Timers
13 8 2 4000 0.00% 0.00% 0.00% 0 Entity MIB API
14 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
15 0 5254 0 0.00% 0.00% 0.00% 0 GraphIt
16 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
17 0 2 0 0.00% 0.00% 0.00% 0 SMART
18 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
19 20 1283 15 0.00% 0.00% 0.00% 0 Net Background
20 0 37 0 0.00% 0.00% 0.00% 0 Logger
21 24 5241 4 0.00% 0.00% 0.00% 0 TTY Background
22 8 5359 1 0.00% 0.00% 0.00% 0 Per-Second Jobs
23 0 2 0 0.00% 0.00% 0.00% 0 SM Monitor
24 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser
25 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov
26 20 174 114 0.00% 0.00% 0.00% 0 Net Input
27 8 1053 7 0.00% 0.00% 0.00% 0 Compute load avg
28 2416 90 26844 0.00% 0.04% 0.00% 0 Per-minute Jobs
29 0 5 0 0.00% 0.00% 0.00% 0 Service-module a
30 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
31 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
32 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
33 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
34 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
35 1523 2239 680 0.00% 0.00% 0.00% 0 IP Input
36 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
37 100 723 138 0.00% 0.00% 0.00% 0 CDP Protocol
38 0 4 0 0.00% 0.00% 0.00% 0 PPP Hooks
39 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
40 76 862 88 0.00% 0.00% 0.00% 0 TCP Timer
41 4 2 2000 0.00% 0.00% 0.00% 0 TCP Protocols
42 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
43 761 617 1233 0.00% 0.00% 0.00% 0 HTTP CORE
44 8 3 2666 0.00% 0.00% 0.00% 0 PPP IP Route
45 0 4 0 0.00% 0.00% 0.00% 0 PPP IPCP
46 385 208 1850 0.00% 0.00% 0.00% 0 IP Background
47 4 10 400 0.00% 0.00% 0.00% 0 IP RIB Update
48 0 89 0 0.00% 0.00% 0.00% 0 Adj Manager
49 41 10150 4 0.00% 0.00% 0.00% 0 CEF process
50 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper
51 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
52 24 16 1500 0.00% 0.00% 0.00% 0 DHCPD Receive
53 0 90 0 0.00% 0.00% 0.00% 0 IP Cache Ager
54 0 1 0 0.00% 0.00% 0.00% 0 COPS
55 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
56 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
57 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
58 0 216 0 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
59 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
60 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
61 4 2 2000 0.00% 0.00% 0.00% 0 LINE AAA
62 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
63 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
64 40 162986 0 0.00% 0.01% 0.00% 0 PPP manager
65 4 2 2000 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
66 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
67 0 44 0 0.00% 0.00% 0.00% 0 DHCPD Timer
68 132 162990 0 0.00% 0.00% 0.00% 0 PPP Events
69 12 19 631 0.00% 0.00% 0.00% 0 DHCP Client
71 12 186 64 0.00% 0.00% 0.00% 0 CEF Scanner
72 4 1486 2 0.07% 0.00% 0.00% 0 DHCPD Database
73 4 5210 0 0.00% 0.00% 0.00% 0 Multilink PPP
74 0 1 0 0.00% 0.00% 0.00% 0 SNMP Timers
75 93 197 472 0.00% 0.00% 0.00% 0 RIP Router
76 4 380 10 0.00% 0.00% 0.00% 0 RIP Send
77 4 901 4 0.00% 0.00% 0.00% 0 RIP Timers
78 4 1 4000 0.00% 0.00% 0.00% 0 IP SNMP
79 0 1 0 0.00% 0.00% 0.00% 0 PDU DISPATCHER
80 60 1 60000 0.00% 0.00% 0.00% 0 SNMP ENGINE
81 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
82 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
------------------ show process cpu history ------------------
HTSH 01:29:33 AM Monday Mar 1 1993 UTC
11111
22221111188888333331111199999 5555
100
90
80
70
60
50
40
30
20 *****
10 ***** ***** *****
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
1
6 1 43121331 1 5 21111
100
90
80
70
60
50
40
30
20
10 * * *
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
2
4
100
90
80
70
60
50
40
30
20 *
10 *
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
------------------ show context ------------------
No valid exception information to display.
------------------ show diag ------------------
Slot 0:
C2610 1E Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 2.3
PCB Serial Number : JAD04400RWN (2521382744)
Part Number : 73-2839-13
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : C0
Deviation Number : 0-0
Product (FRU) Number : C2610 - 1E
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 91 41 02 03 C1 18 4A 41 44 30 34 34
0x10: 30 30 52 57 4E 20 28 32 35 32 31 33 38 32 37 34
0x20: 34 29 82 49 0B 17 0D 04 00 81 00 00 00 00 42 43
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1 BT8360
Hardware revision 1.3 Board revision C0
Serial number 20093101 Part number 800-03279-03
FRU Part Number WIC-1DSU-T1=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 32 98 AD 50 0C CF 03 00 00 00 00
0x30: 60 00 00 00 00 07 27 01 FF FF FF FF FF FF FF FF
------------------ show c2600 ------------------
C2600 Platform Information:
Interrupts:
Assigned Handlers...
Vect Handler # of Ints Name
00 805121D0 00000000 Xilinx bridge error interrupt
01 80495824 00147CDA MPC860 TIMER INTERRUPT
02 805063E8 00000DA1 16552 Con/Aux Interrupt
04 80510D14 00000000 PA Network Management Int Handler
05 80503AAC 00000000 Timebase Reference Interrupt
06 80510D64 00002C62 PA Network IO Int Handler
07 80510E28 00003649 MPC860 CPM INTERRUPT
IOS Priority Masks...
Level 00 = [ EF000000 ]
Level 01 = [ EC000000 ]
Level 02 = [ E8000000 ]
Level 03 = [ E0000000 ]
Level 04 = [ E0000000 ]
Level 05 = [ E0000000 ]
Level 06 = [ C0000000 ]
Level 07 = [ 00000000 ]
SIU_IRQ_MASK = FFFFFFFF SIEN = EF00xxxx Current Level = 00
Spurious IRQs = 00000000 SIPEND = 0000xxxx
Interrupt Throttling:
Throttle Count = 00000000 Timer Count = 00000000
Netint usec = 00000FA0 Netint Mask usec = 000003E8
Active = 0 Configured = 0
Longest IRQ = 00000000
IDMA Status:
Requests = 00009980 Drops = 00000000
Complete = 00009980 Post Coalesce Frames = 00009980
Giant = 00000000
Available Blocks = 256/256
PLD Status:
PLD version information not available.
DIMM Slot 0:
DIMM Type : Dual-bank
DIMM Size : 32MBytes
DIMM Slot 1:
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show inventory ------------------
NAME: "2610 chassis", DESCR: "2610 chassis, Hw Serial#: JAD04400RWN (2521382744), Hw Revision: 0x203"
PID: , VID: 0x203, SN: JAD04400RWN (2521382744)
------------------ show region ------------------
Region Manager:
Start End Size(b) Class Media Name
0x03C00000 0x03FFFFFF 4194304 Iomem R/W iomem
0x60000000 0x60FFFFFF 16777216 Flash R/O flash
0x80000000 0x83BFFFFF 62914560 Local R/W main
0x80008098 0x80CD8A7B 13437412 IText R/O main:text
0x80CD8A7C 0x8128243F 5937604 IData R/W main:data
0x812244F4 0x812823DF 384748 Local R/W data:firmware
0x81282440 0x8147B37F 2068288 IBss R/W main:bss
0x8147B380 0x83BFFFFF 41438336 Local R/W main:heap
------------------ show buffers ------------------
Buffer elements:
500 in free list (500 max allowed)
6880 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
50 in free list (20 min, 150 max allowed)
10929 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 34, permanent 25, peak 34 @ 01:27:48):
30 in free list (10 min, 150 max allowed)
1904 hits, 3 misses, 0 trims, 9 created
Big buffers, 1536 bytes (total 50, permanent 50):
50 in free list (5 min, 150 max allowed)
284 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 20 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
0 in free list (0 min, 4 max allowed)
Interface buffer pools:
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
0 in free list (0 min, 0 max allowed)
0 hits, 0 fallbacks
Header pools:
Header buffers, 0 bytes (total 137, permanent 128, peak 137 @ 01:29:42):
9 in free list (10 min, 512 max allowed)
125 hits, 3 misses, 0 trims, 9 created
128 max cache size, 128 in cache
0 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
128 in free list (128 min, 1024 max allowed)
256 hits, 0 misses, 0 trims, 0 created
256 max cache size, 256 in cache
Normal buffers, 1548 bytes (total 512, permanent 512):
384 in free list (128 min, 1024 max allowed)
184 hits, 0 misses, 0 trims, 0 created
Private particle pools:
Ethernet0/0 buffers, 1536 bytes (total 96, permanent 96):
0 in free list (0 min, 96 max allowed)
96 hits, 0 fallbacks
96 max cache size, 64 in cache
9606 hits in cache, 0 misses in cache
Serial0/0 buffers, 1548 bytes (total 48, permanent 48):
0 in free list (0 min, 48 max allowed)
48 hits, 0 fallbacks
48 max cache size, 24 in cache
1926 hits in cache, 0 misses in cache
