[OT] Computer cases
Bruce,
If you are looking for an off the shelf answer...
BR Metal Technology makes a product, not inexpensive, that has extended the
life of our shop floor PCs.
Our biggest problem is heat, so we pipe the vent in the back of the case to
the outside to draw in fresh air. The cases have taken a beating (shop
floor mishandling) but the computers have done rather well (other than
replacing the occasional $2 and $5 keyboard and mouse).
http://www.brmetal.com/igjrcallout.html
Otherwise, if you would like to keep the PC, look at constructing a box and
as Wayne notes, put positive air pressure to it, with a filter.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Bruce Butler
Sent: Wednesday, May 23, 2007 8:40 AM
Subject: RE: [Vantage] [OT] Computer cases
That is exactly what it is. It is an older card that works. We are
using Ethernet to serial for a subset of machines. The Comtroller is
servicing 16 machines. It would require a lot of re-cabling as well as
the cost of a replacement unit. I would rather keep this going since it
works.
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Mark Wonsil
Sent: Wednesday, May 23, 2007 6:49 AM
> We are running thin clients for this purpose. The problem is the
particular
> PC I am referring to has an expensive to replace ISA card in it for
> communicating to the machines.
Is it like a Comtrol multiple serial card? How many machines does it
serve
Bruce? For the cost of a new PC, there are ethernet-to-serial devices
that you
can put out there:
http://www.comtrol.com/products/catalog.asp?product=dmsh
<http://www.comtrol.com/products/catalog.asp?product=dmsh>
@ $740/8 Ports and @$1080 for 16 Ports
Mark W.
I am looking for a recommendation for protecting a shop floor pc from
the oily environment. Any recommendations?
Bruce Butler, IT Manager
Knappe & Koester, Inc. <http://www.knappe-koester.com>
18 Bradco Street
Keene, NH
p. 603-355-1166
f. 603-355-2266
bbutler@...
The information in this message is proprietary and/or confidential and
is intended only for the use of the individual(s) named above. This
message should not be forwarded without permission from the author. If
this message is received in error or otherwise by someone other than the
addressee, please contact the author at the above number and return the
message or destroy it. In addition, the recipient of this data agrees to
abide by the United States Export Control of Technical Data and
Equipment under the International Traffic in Arms Regulations (ITAR) and
Export Administration Regulations (EAR). The recipient agrees to abide
by these laws and their regulations not only for export and re-export,
but for disclosure to non-U.S. citizens.
I wish I new because we have about 12 machines on the floor and they are in
horrible condition. None of the CD/DVD drives work on the older ones and
they are only 2/3 years old (on the floor about 1.5 years)...
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
> bbutler@... <bbutler%40knappe-koester.com>
This is exactly the reason I am considering TS and thin clients (with no
fans) for the shop when we migrate to 8.x and the Celeron 500Mhz systems
won't suffice. I shudder every time I have to open a shop floor PC for
a repair and find the gunk inside.
-Todd C.
_____
Of zjumper
Sent: Tuesday, May 22, 2007 7:33 AM
Subject: Re: [Vantage] [OT] Computer cases
in
<http://www.knappe-koester.com> >
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
> bbutler@... <mailto:bbutler%40knappe-koester.com>
the
the
to
and
Couldn't agree more. The best solution to dealing with the realities of a
shop floor environment is to not place the hardware on the floor. With
that, there are two options; thin clients or blade PC's. In an ideal world,
I prefer the blade solution because it eliminates the single point of
failure problem but as a shop floor solution they are more expensive. Since
the floor usually runs only a tiny subset of the app, it's the perfect
target for thin clients.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
Todd Caughey
Sent: Tuesday, May 22, 2007 5:49 AM
-Todd C.
_____
Behalf
Of zjumper
in
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
the
the
to
and
We are running thin clients for this purpose. The problem is the particular
Todd Caughey
Sent: Tuesday, May 22, 2007 8:49 AM
-Todd C.
_____
Behalf
Of zjumper
in
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
the
the
to
and
Is it like a Comtrol multiple serial card? How many machines does it serve
Bruce? For the cost of a new PC, there are ethernet-to-serial devices that you
can put out there:
Mark W.
I use a product from a company called Dirt Bag, Inc. It is a bag
filter that encases a pc and protects it from our dirty
manufacturing environment. I use them around all of our MES pc's on
the shop floor and they last for quite awhile. They can be found on
the web at www.dirtbag.biz
Mike Haynes
IT Manager
SAS Global Corp
from
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
> bbutler@...
and
author. If
than the
return the
agrees to
(ITAR) and
abide
export,
works.
Bruce Butler
IT Manager
_____
Of Mark Wonsil
particular
serve
that you
can put out there:
Mark W.
We recommend thin clients for the shop floor environment for this reason
as well as it will cut down on the number of maintenance hours as well,
and seeing that everything happens from the server anyway, you have the
option of securing it down much better.
For protecting your keyboard, check this website out:
http://www.prokeyco.com/
Also, you can do a search on google for computer protective covers.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
317.578.2393
jason@...
Of Todd Caughey
-Todd C.
_____
Behalf
Of zjumper
in
> 18 Bradco Street
> Keene, NH
> p. 603-355-1166
> f. 603-355-2266
the
the
to
and
For a DIY solution (best for PCs not already full of shop gack), you can re-do the case fan(s) so they run positive pressure.
The normal case design that exhausts the enclosure is really stupid. By sucking air out, fresh air and dirt comes in via any route it can find (like your CD drawer). If you pressurize the case, if comes in at the fan ONLY, and you can install a filter there. I used to do this when recycling old office PCs for shop use. Newer PCs put out so much more heat, I can't say for sure if you could do this without burning something up.
You could also build an enclosure with pressurized ventilation to go around the whole PC, but I know there are companies out there selling them pre-built... just have to google some more.
-Wayne
