Ot Dell Optoplex overheat
John,
I have about 20 of these machine everyone did the same thing. My problem
was the cap's on the motherboard. Dell had a batch off bad capacitors and
they all are going bad. If you look at the cap's on the motherboard you
will notice they have a slight bump. You have to look close because it is
hard to see some of them. I would bet that is the problem.
Have a Nice Day,
Dina Hieber
Vamco International, Inc.
Phone (412) 963-7100
Fax; (412) 963-7160
www.vamcointernational.com
Todd Caughey
Sent: Tuesday, January 10, 2006 9:45 AM
Subject: RE: [Vantage] ot Dell Optoplex overheat
Does it give any POST beep code at all or nothing?
Do the fans spin up or does the hard drive spin up at all?
If neither I would suspect a bad motherboard since I've seen the same and a
new MB fixed it.
If you do get a beep code there are plenty of web sites with charts for
looking up what they mean (like a long and three shorts being an unseated
video card).
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
mansfield1024
Sent: Tuesday, January 10, 2006 8:35 AM
Subject: [Vantage] ot Dell Optoplex overheat
Hi Everyone,
I am trying to troubleshhot an Optoplex gx270 that will not boot.
I replaced the power supply.
I replaced all the fans.
I checked the cpu.
I reapplied the thermal stuff between chip and heatsink.
I am lost.
I checked Dell's wonderful techsupport.
Anyone have an idea.
John Mansfield
General Sheet Metal
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage>
" on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
Yahoo! Groups Links
Hi Everyone,
I checked the cpu.
I am lost.
John Mansfield
General Sheet Metal
If neither I would suspect a bad motherboard since I've seen the same and a new MB fixed it.
If you do get a beep code there are plenty of web sites with charts for looking up what they mean (like a long and three shorts being an unseated video card).
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of mansfield1024
Hi Everyone,
I checked the cpu.
I am lost.
John Mansfield
General Sheet Metal
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
Any activity at all? Any beep codes or video display? Probably the system
board. Have you removed all cards but the video card?
Darren Mann
IT Manager
Miller Products Co.
1015 N. Main St.
Osceola, IA 50213
Ph. 641-342-2103
Fax 641-342-3222
mansfield1024
To: Darren Mann
Hi Everyone,
I checked the cpu.
I am lost.
John Mansfield
General Sheet Metal
Yahoo! Groups Links
Hi Todd,
The fans spin, the hard drive spins up and starts windows. The progress
bar gets about 80% of the way when the machine shuts down. I have
changed the hard drive to see if it was a virus. Same thing happens.
Thanks for your help,
John Mansfield
General Sheet Metal
Can you boot in safe mode? If not it begins to sound like bad memory. Have you swapped that from a good machine as a test?
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of John Mansfield
Sent: Tuesday, January 10, 2006 8:50 AM
Hi Todd,
John Mansfield
General Sheet Metal
_____
YAHOO! GROUPS LINKS
_____
Hi Todd,
I have tried safemode and the same thing.
I have swapped out memory and the same thing.
At this point changing the motherboard may be the best answer.
I think I may mount this one on the wall, framed with a Dell Logo.
John Mansfield
General Sheet Metal
John,
This is almost 100% motherboard. Dell (along with several other
manufacturers) had some bad capacitors get into their supply chain
over the past couple of years. This affected all the Optiplex
models. Look at the large canister caps around the processor. See if
any of them have "pushed up" tops instead of being flat. If so,
that's your problem. There are several articles on the web about
this. Google for optiplex and capacitor.
Ron C.
--- In vantage@yahoogroups.com, "mansfield1024" <johnm@g...> wrote:
> Hi Everyone,
> I checked the cpu.
> I am lost.
> Thanks,
> John Mansfield
> General Sheet Metal
John,
Ron is exactly right - we had the same issue last year on about half a
dozen GX270s. Call Dell and have them send out a tech rep with a new
motherboard for you.
have fun,
john
mansfield1024 wrote:
> Hi Everyone,
> I checked the cpu.
> I am lost.
> Thanks,
> John Mansfield
> General Sheet Metal
Thanks to you all,
I spoke with Dell. Went through their 10,000 questions and they will
send out a replacement board.
John Mansfield
General Sheet Metal
