OT: dot matrix problems
Hello Rick, Other printers work fine. OTC support tells me its a driver
problem, their solution was to send me a driver for straight ASCII text. I
am now trying to explain to them that I need IBM ProPrinter emulation. I'll
let you know how it turns out.
Mark
Sent: Tuesday, January 21, 2003 7:56 AM
Subject: RE: [Vantage] OT: dot matrix problems
Mark:
Can you print the doc to another printer with the same problem?
If so, I would suspect a glitch with Crystal. Then I would try the usual
dll copy solution (see archives).
If not, then I would tend to suspect the printer. See if you can borrow
another dot matrix to try. If you need one, I have one or two sitting in
mothballs that I could send to you to try out.
Rick Gors
Sent: Monday, January 20, 2003 5:28 PM
I do not have a history to fall back on, we put this printer in use about 2
weeks ago. My guess is this is the first invoice with advanced billing
applied. I did power down and I also printed form different clients. All
the lines on this invoice print correctly except one. I looked at the
crystal report to see if the formatting was unique for this line, it is not.
I looked for control characters on the line and found none. The printer
settings could be the source but I have gone thru them and not found
anything that stands out. What bothers me is that it effects only one
specific line on the form. I'm gonna go see what I can find for newer
drivers.
Mark
Sent: Monday, January 20, 2003 5:07 PM
Since it happened suddenly, and if nothing else changed, I would be looking
hard at the printer settings. I'm not familiar with that printer but I've
had issues with others where the setup gets changed and they stop obeying CR
and LF commends. In COBOL we used to double strike all the time with an
"advancing zero" clause but some printers disobeyed if their settings were
not just right. Maybe something similar is happening where it is missing a
CR but advancing zero lines, printing from the point it left off and then
wrapping to the same line but in the wrong place. Have you powered the
printer off/on to see if it resets to the default or previously saved
settings incase they got changed?
-Todd C.
Sent: Monday, January 20, 2003 4:04 PM
The first thing I tried was printing the canned report but it does the same
thing. I will reload the drivers.
mark
Sent: Monday, January 20, 2003 4:43 PM
Have you tried reinstalling the printer driver? (Look for updated
driver on Web if that doesn't work?)
Are you using Crystal Reports modified form?
First thoughts at large...
Rick Gors
Sent: Monday, January 20, 2003 4:24 PM
To: Vantage Users Group (E-mail)
Subject: [Vantage] OT: dot matrix problems
Hello group, I thought I'd try to change the subject for a moment, (we
are
not using inventory yet so I seem to have escaped the current nightmare
unfolding before my eyes).
We are printing our ARform(invoice) on an OTC 850XL dot matrix printer
using
IBM Prowriter drivers. It seemed to be working fine until 30 minutes
ago.
We printed one invoice with advanced billing. The "Less advanced
billing:"
label and amount print out twice on the same line. The preview looks
good
and if we print to a laser jet it also looks good. I believe this is
related to the printer double striking every character and for some
reason
this line has the double strike out of position by about 2". This is a
6
part form so we need the double strike. Has anyone ever seen this? Any
ideas would be welcome.
Mark
Yahoo! Groups Sponsor
ADVERTISEMENT
and
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/.> > >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/messages> > >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
<http://groups.yahoo.com/group/vantage/links> > >
ADVERTISEMENT
ADVERTISEMENT
http://rd.yahoo.com/M=241773.2861420.4212388.1925585/D=egroupweb/S=170500718
<http://rd.yahoo.com/M=241773.2861420.4212388.1925585/D=egroupweb/S=17050071
8>
8>
3:HM/A=1394045/R=0/*
http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_5802
<http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_5802>
< http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_5802
<http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_5802> >
,FF.html
83:HM/A=1394045/R=0/*
<http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_580>
<http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_580> >
2,FF.html> > HGTV Dream Home Giveaway
http://us.adserver.yahoo.com/l?M=241773.2861420.4212388.1925585/D=egroupmail
<http://us.adserver.yahoo.com/l?M=241773.2861420.4212388.1925585/D=egroupmai
l>
l>
/S=:HM/A=1394045/rand=654103256
l/S=:HM/A=1394045/rand=654103256> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > >
ADVERTISEMENT
83:HM/A=1394046/R=0/*
2,FF.html> HGTV Dream Home Giveaway
l/S=:HM/A=1394046/rand=687174625>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > .
ADVERTISEMENT
http://rd.yahoo.com/M=241773.2861422.4212389.1925585/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=241773.2861422.4212389.1925585/D=egroupweb/S=17050071
83:HM/A=1394044/R=0/*
http://us.adserver.yahoo.com/l?M=241773.2861422.4212389.1925585/D=egroupmai
<http://us.adserver.yahoo.com/l?M=241773.2861422.4212389.1925585/D=egroupmai
l/S=:HM/A=1394044/rand=166625626>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
83:HM/A=1394044/R=0/*http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_580
l/S=:HM/A=1394044/rand=412838262>
Hello group, I thought I'd try to change the subject for a moment, (we are
We are printing our ARform(invoice) on an OTC 850XL dot matrix printer using
IBM Prowriter drivers. It seemed to be working fine until 30 minutes ago.
We printed one invoice with advanced billing. The "Less advanced billing:"
label and amount print out twice on the same line. The preview looks good
related to the printer double striking every character and for some reason
this line has the double strike out of position by about 2". This is a 6
Mark
Rick Gors
using
billing:"
Mark
ADVERTISEMENT
mark
Rick Gors
are
using
ago.
billing:"
good
reason
6
Mark
ADVERTISEMENT
and
ADVERTISEMENT
Since it happened suddenly, and if nothing else changed, I would be looking hard at the printer settings. I'm not familiar with that printer but I've had issues with others where the setup gets changed and they stop obeying CR and LF commends. In COBOL we used to double strike all the time with an "advancing zero" clause but some printers disobeyed if their settings were not just right. Maybe something similar is happening where it is missing a CR but advancing zero lines, printing from the point it left off and then wrapping to the same line but in the wrong place. Have you powered the printer off/on to see if it resets to the default or previously saved settings incase they got changed?
-Todd C.
mark
Rick Gors
are
using
ago.
billing:"
good
reason
6
Mark
ADVERTISEMENT
and
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=241773.2861420.4212388.1925585/D=egroupweb/S=1705007183:HM/A=1394045/R=0/*http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_5802,FF.html> HGTV Dream Home Giveaway
<http://us.adserver.yahoo.com/l?M=241773.2861420.4212388.1925585/D=egroupmail/S=:HM/A=1394045/rand=654103256>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
drivers.
Mark
-Todd C.
mark
Rick Gors
are
using
ago.
billing:"
good
reason
6
Mark
ADVERTISEMENT
and
ADVERTISEMENT
ADVERTISEMENT
,FF.html
ADVERTISEMENT
83:HM/A=1394046/R=0/*http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_580
Mark:
Rick Gors
drivers.
Mark
-Todd C.
mark
Rick Gors
are
using
ago.
billing:"
good
reason
6
Mark
ADVERTISEMENT
and
ADVERTISEMENT
ADVERTISEMENT
8>
,FF.html
l>
ADVERTISEMENT
ADVERTISEMENT
