Its mostly Progress that is the issue. When you create a window/dialog box in Progress under the properties in the advanced tab there is a section for Geometry X & Y, this is the default windows location it will start with. So because the Epicor programmers write all the windows to work on a single screen, the default locations of the sub windows are going to be on the primary screen. No way around it unless its location is coded into the window/dialog box properties. :(
"It gets more entertaining the more monitors you add."
Yeah, nothing like having a quad monitor setup..... :) What's really cool is running RDP on the different monitors, no need for a KVM switch, just move the mouse to that computer screen!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Aaron Hoyt
Sent: Friday, July 29, 2005 8:06 AM
Subject: RE: [Vantage] Re: OT: Dual Monitors
Ben,
I have played with this before. Ended up moving my icons and start
menu/menu bar to the second monitor. The it appears like the first monitor.
Vantage has it's own rules about where it pops up unlike windows
applications.
Good luck,
Aaron Hoyt
Vantage Plastics
Of bbelzer42
Sent: Thursday, July 28, 2005 5:26 PM
Subject: [Vantage] Re: OT: Dual Monitors
That seems to work with Outlook and Firefox and maybe a few other
programs. Does not work with Vantage. I can just use Monitor 1 for
vantage, but it would be ideal on Monitor 2.
Ben
--- In vantage@yahoogroups.com, "Podlin, Michael"
<michael.podlin@v...> wrote:
to the screen position it was originally developed/designed in?
access. )
Yahoo! Groups Links
Yahoo! Groups Links
Of Aaron Hoyt
Ben,
applications.
Good luck,
Aaron Hoyt
Vantage Plastics
Of bbelzer42
Ben
> what if you moved the new window to the second screen and closed itthen opened it again? Does it retain, or is it trying to result back
>Behalf
> Of bbelzer42
> Sent: Thursday, July 28, 2005 3:36 PM
> Thanks, that was a good tip, but I actually may have worded it wrong.
> What happens is when I am on monitor 2, in Vantage, I will click on a
> favorite (ie Order Entry) and the new smaller order entry window
> appears in monitor 1 and not 2 where the main program is. Does that
> make sense?
> Thanks for your help!
> Ben
> > You can try putting the short cut in the window/monitor you want to
> start it from.
> > The other issue, if you're starting from a .vtg or .mfg file, the
> exe might be launching it to the main window. In this case you might
> be able to have it run on the other monitor by creating the shortcut
> in long hand mode (type out the full command line to start vantage).
> > Of bbelzer42must have already linked your email address to a yahoo id to enable
> > Sent: Thursday, July 28, 2005 2:46 PM
> > Subject: [Vantage] OT: Dual Monitors
> > I just setup dual monitors so I can have Vantage open on one monitor
> > (the extra one) and run everything else on the other.
> > The problem I have is that everytime I click on a shortcut, it opens
> > in the first monitor. Is there a setting where new windows will open
> > where the program is?
> > Thanks,
> > Ben
> access. )
> > Yahoo! Groups Links
access. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups LinksUseful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
Yahoo! Groups Links
Yahoo! Groups Links
