OT: firewalls and Hotmail
Do you visit any other secure sites? If so do they work? Chance are
you SSL ports on the firewall are not open. In order to protect your
information hotmail encrypts your sessions. Port 443 on the firewall
needs to be open in order to use SSL encrypted web sessions. An
example of a different encrpyted site would be on-line shopping. If
you order anything on-line you should see a little lock in the lower
right hand corner of you browser. This tells you that the site is
secure. Well, you hope so anyway. If the firewall came from your
cable ISP, tell them to fix the problem.
--- In vantage@y..., Tricia Simon <t.simon@r...> wrote:
> Sorry to post a non-Epicor related question, but I know there are
many
> techies on this list and I'm definitely NOT one of them! :) Thanks
in
> advance for any info you may be able to share.
> We went from an ISDN-line to a cable for Internet access at work.
With the
> cable came the introduction of a firewall due to a static IP
address.
> I can now access all my normal sites on the web with the exception
of
> Hotmail. The initial sign-in page will come up but once the data is
> entered, that's as far as it goes. I've only waited approx 3-4
minutes each
> time, but I don't seem to get any error message....just nothing!
> My hunch is that this has to do with the firewall, but I'm not
sure. Any
> ideas?
> BTW, I'm using Internet Explorer.
> TIA!
> Tricia Simon, Controller
> Riten Industries, Inc.
Sorry to post a non-Epicor related question, but I know there are many
techies on this list and I'm definitely NOT one of them! :) Thanks in
We went from an ISDN-line to a cable for Internet access at work. With the
cable came the introduction of a firewall due to a static IP address.
I can now access all my normal sites on the web with the exception of
entered, that's as far as it goes. I've only waited approx 3-4 minutes each
My hunch is that this has to do with the firewall, but I'm not sure. Any
ideas?
TIA!
