OT - Freeware
Thanks so much, I use DOS so seldom, didn't even think of that!
You folks are great!
Lydia
Could anyone recommend a piece of freeware that lists the contents of a folder into notepad or Word so that it can be printed?
I found something called FileMonkey, but can't get any reviews on it.
Lydia
<http://geo.yahoo.com/serv?s=97359714&grpId=20369&grpspId=1600007183&msgId=50574&stime=1150984788>
As an old "DOS Head", try opening a "dos" window using cmd.exe from
Start > Run
Find your folder (cd\....)
dir *.* > c:\temp\filecontents.txt
Best Regards,
Paul Whittle
Of Lydia Coffman
Sent: 22 June 2006 17:26
Subject: RE: [Vantage] OT - Freeware
Lydia
Id=50574&stime=1150984788> >
Click here
<https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
0DJ0E6nux2uzfJgSAd!22iIT4Bv+!sOzGwkc9rA7Wqx50uKV3!fWDfkenAfUVltpbFlZH+Fr
HVkL!GHIo3v+z1Ieg5MG8+940fQNDG8yfhZ+eHfVjXUO!QQJJz081dc1hbVoN2pjGuAbcC1h
ZOef414SE5NGIuI2avHMvuf3uH4E1TbyYcKKgc0N> to report this email as spam.
Lydia,
You're working to hard ...
Start / run - "CMD" - command prompt
Change to the directory in question.
Type "DIR *.* >contents.txt
The ">" is an old unix redirector that sends the output of any DOS style
command to a file instead of the screen.
Todd Anderson
_____
Lydia Coffman
Sent: Thursday, June 22, 2006 11:26 AM
Lydia
<http://geo.yahoo
788>
You can always use DIR in the command prompt mode or TREE.
see DIR /? or TREE /? for options.
DIR *.* /s > dirlist.txt (this will show all files in subdirectories)
or
TREE > treelist.txt (this will show the directory structure)
or
TREE /F > treelist.txt (this will show the files within the directory structure)
TREE c:\windows /F > treelist.txt (this will show the files and directory structure starting at the c:\windows path)
Then just open the file with the EDIT, NOTEPAD, or what you like.
Charles
----- Original Message -----
Sent: Thursday, June 22, 2006 12:26 PM
Lydia
I have an MS Access Database/Macro that recurses a folder's subfolders
and drops the file/path and the Last Modified Date into a table. A bit
of overkill for your needs, but you can run queries against the Datetime
stamps and verify alot of other things, at least that is what we use it
for.
Andrew Reed
Of Lydia Coffman
Lydia
Using DIR from a command prompt with a redirector is probably the
easiest way, but if you want to do it programmatically go to
www.sysinternals.com <http://www.sysinternals.com/> , they have lots of
free admin toys and utilities.
Of Lydia Coffman
Lydia
Lydia,
If you just want to print it then skip the redirect to folder idea
and just redirect to the printer. If you have a printer directly
connected to the PC then type in at the DOS prompt dir *.* > lpt1.
If you want to redirect to a shared printer and have permission to
print to it on your network then type dir *.* >
\\computername\printersharename.
BTW, if you use two redirection symbols (>>) then it will append to
the file instead of creating it new each time.
HTH
Mike
it.
> Thanks,
> Lydia
8>
