[OT] Help with Crystal Enterprise
Thanks for responding, Wendy. I'll look at your suggestions.
Update: I downloaded a Crystal Document concerning the error message "Communication Error" and it gave about 5 different areas to check, including permissions as you suggest. One 'test' that didn't check out for me was the host name in the Crystal Web Component Server matching the name in the WCHosts in the registry. Also, the APS Services are not registered correctly. There is an error in the Event Viewer saying that APS could not be registered.
Question: The host name on this box has spaces in it: NET ENG SERVER. Would that possibly cause some of these hangup? It doesn't seem to affect any other areas on the server, except that in DNS you can't use the computer's name... we use NET_ENG_SERVER because it won't accept the spaces... then it gives us a warning that the computer will have a different name on the internet than it will locally. Interestingly, the host name in the registry under WCHosts was "net_eng_server". I changed the name in the registry, but it didn't fix the problem after rebooting. Does anyone have any ideas about host names with spaces affecting Crystal Enterprise?
Thanks for any responses.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Wednesday, November 27, 2002 6:36 AM
Subject: Re: [Vantage] Re: [OT] Help with Crystal Enterprise
Troy,
I also had that particular error when I switched over to Active Directory. I ended up clicking the "Windows Authentication" box in the Crystal area in IIS. That go rid of that error. Then I ended up fiddling with permission settings throughout the Crystal area of IIS to get it to stop prompting for a password.
~Wendy
Sent: Tuesday, November 26, 2002 4:44 PM
Update so far...
Everyone's comments so far have helped. I discovered the the file extensions were not set up, and that the 'veiwer' directory referenced by Wendy's email was not there. Thus, i reinstalled Crystal Enterprise.
Now, when I browse a Crystal directory, I get the following message in the IE browser window.
"COMMUNICATION ERROR" -- Communication failed with all configured Web Component Servers because they are disabled or not currently running. If this problem continues, please contact the system administrator.
I plan to reboot the server at the end of the day when noone is connected to files. But in the meantime, does anyone have a clue what I should do about the above message?
Troy Funte
Liberty Electronics
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> The client workstation can view a crystal report on the OLD server
(which is still running by the way) just fine. The Crystal Viewing
objects are installed in IE just fine. My guess is that it is
something in IIS that is not configured correctly.
> I tried putting a default.htm web page in the /reports directory,
but all I see is the 'source code' of the .htm file, not the web page
itself.
> Troy Funte
> From: Ted Kitch
> To: 'vantage@y...'
> Sent: Tuesday, November 26, 2002 12:00 AM
> Subject: RE: [Vantage] [OT] Help with Crystal Enterprise
> Some of the components are missing on either the server or
client. Did the
> client download the ActiveX control? Every time that I have seen
this
> behavior it has something to do with the client not having the
ActiveX
> control on the viewing computer. I have read where there can be
a server
> configuration error, but this was only for DHTML reports.
> I would download the ActiveX control again and see if that takes
care of the
> proplem.
> Ted Kitch
> ted@m...
> -----Original Message-----
> From: Troy Funte [mailto:tfunte@e...]
> Sent: Monday, November 25, 2002 8:27 PM
> To: Vantage
> Subject: [Vantage] [OT] Help with Crystal Enterprise
> I can't seem to get Crystal Reports to 'view' in IE browsers on
our new
> Crystal Enterprise server.
> I am attempting to migrate my Crystal Enterpise Web Component to
a new
> computer. Currently things are running fine on the "NT 4.0
Workstation" PC.
> The new install is on a "NT 4.0 Server" PC.
> I have installed IIS as well as Crystal Enterprise on the new
server. I
> shared a 'reports' directory. When I open IE on another computer
(or any
> computer on the network), I can browse to the directory where the
reports
> are and see the .rpt files. However, when I click on a report
(which is our
> standard method of running reports under our current setup), IE
wants to
> download the file to the local PC RATHER THAN view the report.
> Does anyone know what I'm missing here?
> Troy Funte
> Liberty Electronics
I can't seem to get Crystal Reports to 'view' in IE browsers on our new Crystal Enterprise server.
I am attempting to migrate my Crystal Enterpise Web Component to a new computer. Currently things are running fine on the "NT 4.0 Workstation" PC. The new install is on a "NT 4.0 Server" PC.
I have installed IIS as well as Crystal Enterprise on the new server. I shared a 'reports' directory. When I open IE on another computer (or any computer on the network), I can browse to the directory where the reports are and see the .rpt files. However, when I click on a report (which is our standard method of running reports under our current setup), IE wants to download the file to the local PC RATHER THAN view the report.
Troy Funte
Liberty Electronics
Some of the components are missing on either the server or client. Did the
client download the ActiveX control? Every time that I have seen this
behavior it has something to do with the client not having the ActiveX
control on the viewing computer. I have read where there can be a server
I would download the ActiveX control again and see if that takes care of the
proplem.
Ted Kitch
ted@...
To: Vantage
Troy Funte
Liberty Electronics
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2675695.4055211.2225243/D=egroupweb/S=17050071
83:HM/A=1267611/R=0/*http:/ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=3
00x250;ord=1038277612622342?>
<http://us.adserver.yahoo.com/l?M=237459.2675695.4055211.2225243/D=egroupmai
l/S=:HM/A=1267611/rand=740090491>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
The client workstation can view a crystal report on the OLD server (which is still running by the way) just fine. The Crystal Viewing objects are installed in IE just fine. My guess is that it is something in IIS that is not configured correctly.
I tried putting a default.htm web page in the /reports directory, but all I see is the 'source code' of the .htm file, not the web page itself.
Troy Funte
To: 'vantage@yahoogroups.com'
proplem.
Ted Kitch
ted@...
To: Vantage
Troy Funte
Liberty Electronics
ADVERTISEMENT
ADVERTISEMENT
Troy,
Have you checked that your IIS configuration?
Go into the properties for the website, Home Directory, Configuration.
The following file extensions need to be setup:-
.rpt, .shtx, .csp, .cri, .cwr
I believe they should be set to "all verbs" and "script engine"
should be checked.The executable will most likely be:-
C:\Program Files\Seagate Software\WCS\wcsinsapi.dll
When you installed Enterprise it should have set this up itself, but
it's worth checking.
Anton Wilson
Deanestor Ltd
itself.
> Troy Funte
> From: Ted Kitch
> To: 'vantage@y...'
client. Did the
this
ActiveX
a server
care of the
> proplem.
> Ted Kitch
> ted@m...
> To: Vantage
our new
a new
Workstation" PC.
server. I
(or any
reports
(which is our
wants to
> Troy Funte
> Liberty Electronics
> ADVERTISEMENT
050071
0;sz=3
must have
access. )
Builder and
> ADVERTISEMENT
access. )
Service.
Troy,
I found this article on the Crystal Decisions support site. I don't know if it applies in your situation, but hopefully it does.
Article ID: c2004405
When running a report from a client computer in a Microsoft Internet Explorer the web components prompt you to install the ActiveX viewer. However, one of the following situations arises:
1. Red "X" Displays in the top-left corner of the browser window.
2. Error message appears in the browser window.
3. Gray border displayed in place of the viewer.
4. Blank browser window.
5. Empty, gray browser window.
Solution
A. For detailed causes and troubleshooting of the installation of the ActiveX Viewer download the document "Crystal_Web_Viewer_for_Actx.pdf" by searching by file name from the following location:
http://support.crystaldecisions.com/docs
B. The two most common causes for the ActiveX Viewer being incorrectly installed are:
1. Incorrect configuration of the "viewer" virtual directory on the website serving the reports. To correct this problem, follow these steps:
For WINDOWS NT 4.0 AND INTERNET INFORMATION SERVER 4.0, follow these steps:
a) Open the Microsoft Management Console using Start > Programs > Windows NT 4.0 Option Pack > Microsoft Internet Information Server > Internet Service Manager
b) Double-click on the "Internet Information Server" folder
c) Double-click on the "<computername>" computer icon
d) Double-click on the "Default Web Site" icon
e) Right-click on the "viewer" virtual directory and a menu appears. Choose "Properties" from the menu
f) In the "Directory" tab check the "Permissions" in the bottom left corner. Enable only the "None" radio button
g) Click "OK" and close the Microsoft Management Console
Now run the report again from the Internet Explorer browser.
For WINDOWS 2000 SERVER AND INTERNET INFORMATION SERVICES 5.0, follow these steps:
a) Open the Internet Information Services console using Start > Settings > Control Panel > Administrative Tools > Internet Services Manager
b) Double-click on the "<computername>" computer icon
c) Double-click on the "Default Web Site" icon
d) Right-click on the "viewer" virtual directory and a menu appears. Choose "Properties" from the menu
e) Choose "None" from the "Execute Permissions" drop down list
f) Click "OK" and close the Internet Information Service console
2. Corrupted, unrecognizable, or older version of the ActiveX Viewer already installed on the client computer.
The existing ActiveX Viewer should be removed from the client computer before attempting to download the new version. To remove the ActiveX Viewer from the client computer from a Microsoft Internet Explorer 5.0:
a) Right-click on the Internet Explorer icon on the desktop and a menu will appear
b) Select "Properties" from the menu
c) Click on the "Settings" button
d) Click on the "View Objects" button. Under "View Objects" you will see the "Crystal Report Viewer Control"
e) Right-click on the control and choose "Remove". Click "Yes" when prompted to remove the control
f) Close the "Downloaded Program Files" window, click "OK" on the "Settings" window and then click "OK" on the "Internet Options" window
g) Open the browser and run a report in the ActiveX Viewer. The new version will download from the web server
Sent: Tuesday, November 26, 2002 6:01 AM
Subject: Re: [Vantage] [OT] Help with Crystal Enterprise
Troy Funte
proplem.
Ted Kitch
ted@...
To: Vantage
Troy Funte
Liberty Electronics
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Troy,
Goto to your webserver machine. Right-click the folder where you have
stored the Crystal reports, select Properties. You should see the
"Internet" tab - select it. Be sure that WWW is selected as the service
and that the status is "Running". In the "Aliases" box, if you do not
have anything listed, add an Alias and check the properties; My
experience is bullet the Virtual Directory, and check both Read and
Execute under Access.
Hope this helps,
Jim Stetetr
Sent: Monday, November 25, 2002 9:27 PM
To: Vantage
the report.
Troy Funte
Liberty Electronics
ADVERTISEMENT
007183:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B107
1650;sz=300x250;ord=1038277612622342?>
pmail/S=:HM/A=1267611/rand=740090491>
Based on this, you need to look at the extensions that are registered on the
IIS server. Anton emailed about this too. Search the Crystal Decisions KB.
You could probably reinstall IIS and Crystal Enterprise to do this for you
if it wasn't done in the first place. Also make sure that you are running
IIS 4.0 on NT 4 Server. I always had little annoying problems with earlier
versions of IIS on NT 4 server.
Ted Kitch
ted@...
Sent: Tuesday, November 26, 2002 5:01 AM
Troy Funte
the
the
proplem.
Ted Kitch
ted@...
To: Vantage
PC.
our
Troy Funte
Liberty Electronics
ADVERTISEMENT
have
<http://groups.yahoo.com/group/vantage/files/> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
ADVERTISEMENT
ADVERTISEMENT
00x250;ord=1038308456389613?>
l/S=:HM/A=1267611/rand=233398073>
Ted,
I'm not sure which version of IIS I have. Where would I get a fresh version?
Troy
Sent: Tuesday, November 26, 2002 6:05 AM
Ted Kitch
ted@...
Troy Funte
the
the
proplem.
Ted Kitch
ted@...
To: Vantage
PC.
our
Troy Funte
Liberty Electronics
ADVERTISEMENT
have
Terms of Service.
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Update so far...
Troy Funte
Liberty Electronics
itself.
> Troy Funte
> From: Ted Kitch
> To: 'vantage@y...'
client. Did the
this
ActiveX
a server
care of the
> proplem.
> Ted Kitch
> ted@m...
> To: Vantage
our new
a new
Workstation" PC.
server. I
(or any
reports
(which is our
wants to
> Troy Funte
> Liberty Electronics
> ADVERTISEMENT
050071
0;sz=3
must have
access. )
Builder and
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
Troy,
~Wendy
Update so far...
Troy Funte
Liberty Electronics
itself.
> Troy Funte
> From: Ted Kitch
> To: 'vantage@y...'
client. Did the
this
ActiveX
a server
care of the
> proplem.
> Ted Kitch
> ted@m...
> To: Vantage
our new
a new
Workstation" PC.
server. I
(or any
reports
(which is our
wants to
> Troy Funte
> Liberty Electronics
> ADVERTISEMENT
050071
0;sz=3
must have
access. )
Builder and
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
ADVERTISEMENT
