OT- ISA Server
I believe so... Outgoing is local ip with 8002
Incoming is external IP with 8080
Sent: Monday, October 06, 2003 9:03 AM
Subject: RE: [Vantage] OT- ISA Server
Just a quick thought, under servers and arrays is your ISA server. When you
right click on that and go to properties, are your settings for Outgoing web
request and incoming web requests correct?
Jasper
Sent: Monday, October 06, 2003 9:54 AM
thanks. I will be patient.
Sent: Monday, October 06, 2003 8:53 AM
That should work. If it worked before than it should work now. I'm tring
to find out from some people what kind of adjustments you need to make when
you change ISP's
Jasper
Sent: Monday, October 06, 2003 9:47 AM
Jasper
WHat type of protocol rule do I need? I have access to everything for
everyone for the internet.
Sent: Monday, October 06, 2003 8:39 AM
Lois -
This is sounding more like a IP/port blockage. Is your firewall
setup to only route the previous set of IP numbers through?
Check your firewall and/or router IP tables to see what traffic
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Sent: Monday, October 06, 2003 8:20 AM
To: 'vantage@yahoogroups.com'
Did that already.. Still I can not surf. I can ping anything in the outside
world by name or IP just can't get there.
Sent: Monday, October 06, 2003 8:17 AM
Your new provider probably uses it's own DNS servers and if your old
provider turned theirs off or renumbered that would explain your problems.
Happened to me earlier this year. Call your new provider and get their DNS
addresses (2) and plug them into your PC's. Should fix the problem.
Or ... is your router now configured to block web pages ???
Todd Anderson
Sent: Monday, October 06, 2003 7:57 AM
Subject: [Vantage] OT- ISA Server
I don't know if anyone is using an ISA server. We had a new telecom
provider and a new T-1 installed this weekend. All was fine on
Friday. Saturday I changed the IP's as necessary. Now my ISA cvan
not surf the web. It can ping any sites on the outside by either iP
or name and get a response. You can ping from the outside to my
router. Isa just cant seem to bring up web pages. Error out and
says can't find server or DNS error. Any help would be really
appreciated.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=251812.3856299.5103760.1261774/D=egroupweb/S=17050071
83:HM/A=1754452/R=0/SIG=11tjeu2hk/*http://www.netflix.com/Default?mqso=60178
324&partid=3856299> click here
<http://us.adserver.yahoo.com/l?M=251812.3856299.5103760.1261774/D=egroupmai
l/S=:HM/A=1754452/rand=925457990>
appreciated.
Check your DNS Forwarders. Try using NSLookup to make sure it's looking at the right place. How is your DNS setup?
Jasper
Sent: Monday, October 06, 2003 8:57 AM
appreciated.
What am I looking for when using NSLookup? My internal DNS routes to the
local IP number only.
Sent: Monday, October 06, 2003 8:13 AM
Jasper
appreciated.
Todd Anderson
appreciated.
ADVERTISEMENT
Todd Anderson
appreciated.
ADVERTISEMENT
How about your default gateway and DNS settings on the external NIC of the ISA server. Are those consistent with your new provider?
Sent: Monday, October 06, 2003 9:20 AM
Todd Anderson
appreciated.
ADVERTISEMENT
My issue really seems to be that port 80 is closed but I don't see why. you
can not telnet into port 80. Any ideas there?
Just a thought, did you change the actual internal IP address of your ISA server? Is so, is you web proxy setting correct?
Jasper
Sent: Monday, October 06, 2003 9:33 AM
Subject: FW: [Vantage] OT- ISA Server
yes... I have the published ip, their subnet, my router for the gateway.
their DNS 1st and my internal dns second.
Sent: Monday, October 06, 2003 8:27 AM
Todd Anderson
appreciated.
ADVERTISEMENT
Change your proxy setting to port 8080
Sent: Monday, October 06, 2003 9:35 AM
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
It is already set to 8080.
Sent: Monday, October 06, 2003 8:37 AM
ISA server is designed to block port 80. You must use port 8080
Sent: Monday, October 06, 2003 9:39 AM
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
no internal ip of server stayed the same.
Jasper
Todd Anderson
appreciated.
ADVERTISEMENT
Remembering this was all working great until the new T-1. Changed the IP's
on the card, in my internal DNS, on ISA I changed the iP packet filters and
the incoming web request address. That was all that I saw that needed
changing.
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
I did check all that and they are correct.
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
Jasper
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
That should work. If it worked before than it should work now. I'm tring to find out from some people what kind of adjustments you need to make when you change ISP's
Jasper
Jasper
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
you change ISP's
Jasper
Jasper
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
Just a quick thought, under servers and arrays is your ISA server. When you right click on that and go to properties, are your settings for Outgoing web request and incoming web requests correct?
Jasper
you change ISP's
Jasper
Jasper
Lois -
is being allowed.
HTH,
Misha 1, Ltd.
Calvin Dekker
Todd Anderson
appreciated.
ADVERTISEMENT
