They are really different things. NAND in used in things like flash drives
and SSDs. DRAM is your normal RAM. There is a lot of speculation/prediction
that NAND will get fast enough to alleviate the need for RAM, but it's still
a ways off.
To the best of my knowledge, no one makes RAM based on NAND chips as DRAM is
still much cheaper and faster. As the process for making NAND is inherently
more complex and expensive than DRAM, I doubt you will ever see NAND based
memory. I imagine it's more likely that SSDs will simply reach a speed where
conventional RAM is no longer necessary.
On Thu, Jul 21, 2011 at 10:03 AM, Len Hartka
<len.hartka@...>wrote:
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
a ways off.
> Good Day:
> I just saw an article about NAND ( vs. DRAM) memory. Path to the article is
> attached.
> Anyone have any experience with it?
> len.hartka@...
> Of Blake Clemens
> Sent: Thursday, July 21, 2011 9:36 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Database performance(More Memory)
> Task Manager... End Task
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
> mustardbuzzards
> Sent: Thursday, July 21, 2011 9:34 AM
> Subject: [Vantage] Re: Database performance(More Memory)
> Next Question; How does one remove the _proapsv.exe that is left running?
> Thanks
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:
> vantage%40yahoogroups.com> , Chris Thompson <chriselectrix@...> wrote:
> > On a night, stop and start your DBs and Apps and restart them.
> > This helped us.
> > Then we also check task manager on the server to see if there are any
> > _proapsv.exe still left running when Epicor is stopped.
> > We found recently that some _proapsv.exe were left running when
> everything was
> > stopped and they never die. Each ones used 13% CPU so it didnt take many
> days
> > before the system slowed right down.
> > From: "effgroups@..." <effgroups@...>
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:
> > Sent: Thu, 21 July, 2011 1:36:16
> > Subject: Re: [Vantage] Database performance(More Memory)
> > Why don't you setup a batch file to clear your tmp folder every night or
> every
> > other night.
> > For us this solved our slowdowns.
> > Ephraim Feldman
> > Programmer / Analyst
> > Axis Lighting
> > -----Original Message-----
> > From: "mmcwilliams22" <mmcwilliams22@...>
> > Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Date: Tue, 12 Jul 2011 18:28:50
> > To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:
> vantage%40yahoogroups.com> >
> > Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Database performance(More Memory)
> > Prior to adding more memory and upgrading to 2003 enterprise we would
> restart
> > the server due to the fact that the memory usage is at 4GB at the end of
> the
> > week.
> > We have installed additional 8GB of memory but still performance drops
> once we
> > get to that 4GB mark on the memory. I do notice the mfgwrk folder clears
> about
> > 5gb of temp files on the restart as does the oe101b_wrk have about 2gb
> getting
> > cleared.
> > Should I be changing my appserver settings to use the addional memory?
> This e-mail and any attachments may contain proprietary and/or confidential
> information. If you are not the intended recipient, please notify the sender
> immediately by reply e-mail or at 410-472-2900 and then delete the message
> without using, disseminating, or copying this message or any portion
> thereof. With e-mail communications you are urged to protect against
> viruses.
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
