OT: Printing Checks (Payables)
We used to copy each, then went to reprinting on plain paper, then went to
the 2 part check stub retaining one part with vendor invoice(s), and finally
to none of the above. We print the check and send it to the vendor. If we
had to have a paper copy of each check, what would we do about all the
payments made via electronic methods ? Our "copy" of the check is in
Vantage. Went through an audit last year and had no problems. We have
never missed having a copy of the check or the stub. Our goal has been to
eliminate a hard copy of anything that is printed out of Vantage (quotes,
invoices, POs, checks, et.al.). We work to have people understand that we
are retaining a "copy" of each document in Vantage. Each one has been an
adjustment as we eliminated the hard copy but we have never gone back to
keeping paper copies.
Jerry Boyle
Sipco Molding Technologies
Meadville, Pa. 16335-6725
814.724.2243 x53
vantage 5.00.337
Sent: Wednesday, August 14, 2002 2:29 PM
To: Vantage Group (E-mail)
Subject: [Vantage] OT: Printing Checks (Payables)
Hey all,
This issue may have been addressed before, and if so I apologies.
We are considering going to a one copy check for our payables system.
Historically we have used a check that prints in triplicate. I was
wondering how other people set up their system for checks so they can be
laser printed, single copy.
Any suggestions?
Daniel C. Spoerl
Estimator/MIS
Toledo Metal Spinning Co.
Hey all,
Â
Â
We are considering going to a one copy check for our payables system.Â
Â
Any suggestions?
Â
Daniel C. Spoerl
Estimator/MIS
Phone: (419) 535-5931 ext. 203
Fax:Â Â Â (419) 535-0565Â
Personal E-fax: (707) 897-1708Â
Email:Â Â Â HYPERLINK
"mailto:dans@..."dans@...
WebSite: HYPERLINK
"http://www.toledometalspinning.com/"http://www.toledometalspinning.com
HYPERLINK "http://www.toledometalspinning.com/products_configurator.htm" \n
Â
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.377 / Virus Database: 211 - Release Date: 7/15/2002
Dan,
We use laser checks currently. I am assuming the "system" you are referring to is the paperwork.
When we pay an invoice, we stamp the invoice with a paid stamp and write the check number and date of run with the group id #. This then get filed in the vendors file.
Obviously each vendor has there own folder. Now, we also print the group edit list that shows all of the checks and the check number which are in that group. This is kept
in a binder. This is the reason we write the group id # on the invoice - if for some reason we would need to refer back to the group edit list - it would be easy to find
which run it is from. Every 6 months we clear the previous 6 months. (i.e. dec 30 we throw away january to june.) Vendor tracker has always given the information we
needed but we keep the group edit list "just in case".
I hope this helps and this is what you were looking for. .
Dina
dans@... wrote:
> Hey all,
> Any suggestions?
> Thanks,
> Daniel C. Spoerl
> Estimator/MIS
> Fax: (419) 535-0565
> Email: HYPERLINK
> WebSite: HYPERLINK
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100 - phone
(412) 963-9511 - fax
www.vamcointernational.com
We address the issue by reprinting the entire check run on plain paper to
give us a copy of the check to staple to the invoice.
Deb Wilmoth
Controller
Reeder & Kline Machine Company, Inc.
Vantage 5.0
Sent: Wednesday, August 14, 2002 1:29 PM
Hey all,
Â
Â
Â
Any suggestions?
Â
Daniel C. Spoerl
Estimator/MIS
WebSite: HYPERLINK
Â
We put them through the copier. Though, personally, I wonder why even that
is necessary, but then I'm not an accounting type. Others run the check run
twice once blank paper once on the check.
Shirley
Hey all,
Any suggestions?
Daniel C. Spoerl
Estimator/MIS
Fax: (419) 535-0565
Email: HYPERLINK
WebSite: HYPERLINK
\n
Yahoo! Groups Sponsor
ADVERTISEMENT
We have our form devided into 3 parts. Stub-Check-Stub. The only issue is
you cant pay more then 15 items per check. Our AP Person deals with this
without a problem. We send one stub and the check to the vendor and keep
one stub to attach to the Invoice we file here.
Jeremy
Hey all,
Â
Â
Â
Any suggestions?
Â
Daniel C. Spoerl
Estimator/MIS
WebSite: HYPERLINK
Â
If your accountants are happy just to keep a copy of the stub, you can buy
check forms perf'ed in thirds, and print two copies of the stub on each
form. This is tricky to set up on Vantage's Crystal form, but it has been
done. You'll also run into trouble if the operator tries to pay too many
invoices one vendor in a run. You'll need to train them to keep that
limitation in mind, if you go this route. You can also give Epicor Tech
Support a shout and ask them to give you back the ability to configure the
number of invoice details per stub, like you could before version 4.0.
Most check printers offer "multi part" laser forms. These have a regular
pre-numbered check sheet with a duplicate colored copy after each
one. Just print two copies of the run and you're set. These are
reasonably priced, and save a lot of time and copier wear & tear vs running
manual copies. Getting two copies to print automatically can be tricky though.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
Jeremy,
Can you send a copy of the crystal report for your check format.
I currently have checks with a non-negotiable duplicate and run my checks
with a qty of two. This is no problem, but I rarely have more than 15
invoices per check and your format would work great and save $ on forms.
Thanks'
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Sent: Wednesday, August 14, 2002 2:54 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] OT: Printing Checks (Payables)
is
Jeremy
Hey all,
Any suggestions?
Daniel C. Spoerl
Estimator/MIS
Fax: (419) 535-0565
Email: HYPERLINK
WebSite: HYPERLINK
\n
have
ADVERTISEMENT
What is your email address?
Sent: Wednesday, August 14, 2002 2:27 PM
Jeremy,
Thanks'
Controller
Fax: 401-596-1050
is
Jeremy
Hey all,
Any suggestions?
Daniel C. Spoerl
Estimator/MIS
Fax: (419) 535-0565
Email: HYPERLINK
WebSite: HYPERLINK
\n
have
ADVERTISEMENT
efox@...
Controller
Fax: 401-596-1050
Sent: Wednesday, August 14, 2002 3:39 PM
Jeremy,
Thanks'
Controller
Fax: 401-596-1050
is
this
keep
Jeremy
Hey all,
Any suggestions?
Daniel C. Spoerl
Estimator/MIS
Fax: (419) 535-0565
Email: HYPERLINK
WebSite: HYPERLINK
\n
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
