Mike and everyone:
I found this page that has some good info on "How-to" for separator pages.
Kind-of an "Everything you always wanted to know about separators - but were
afraid to ask." I hope to QUICKLY be able to put together a separator page
that is easy to spot in the pile of printouts. The standard ones in windows
are pretty non-descript. If it doesn't take too long, I'll give it a try.
Knock yourselves out, if you're so inclined. -Gary
http://www.genicom.com/drivers/technotes/win/win-09.htm
Sent: Tuesday, March 26, 2002 5:19 PM
Subject: RE: [Vantage] OT - Printjob Header
Gary,
They are text files, edit with Notepad, etc. They can contain PCL /
Postscript code if you want to get fancy. I have no first hand experience
in customising them. There are 3 example .SEP files in the SYSTEM32
directory that you could look at. Sounds like an interesting little
project. Much easier to setup with Novell and Banner pages.
Michael
Sent: Wednesday, 27 March 2002 1:48 AM
Michael,
Thanks for the clear info. Is this PCL or PJL? -Gary
Sent: Monday, March 25, 2002 6:06 PM
A printer separator page is configured by creating a text file using a
number of special control codes. The basic format of the separator page is
as follows
$ ---- this can be any character, and must be the first character on the
first line. Choose a character not normally used to be the control
character, in this case $
$LUser Name $N ---- $L is used to display normal test until another code is
found, $N displayed the username
$L, Job Number $I ---- $I displays the job number
$E ---- $E means end of page
Other characters you can use are
$B$S ---- Turn on block character printing
$D ---- Data job printer
$F<filename> ---- A file to print
$H ---- Printer specific control code
$x ---- Where x is a number of blank lines to print
$T ---- Time job was printed
$U ---- Turns off block character printing
$Wxx ---- Width of the separator page
To configure the printer to use the separator file:
Start the Printer Control Panel Applet (Start - Settings - Printers)
Right Click on a printer and select Properties
Click the "Separator Page" button
Enter the path and file name of the separator page file and click OK
Click OK again to exit the Printer Setup
Gary,
Michael
Michael,
as follows
