OT: Processor crunching away
Hey -
Use Task Manager to look for any suspicious processes that are running and
kill them.
If running XP use msconfig to disable anything strange.
If running 2000 copy msconfig from an XP pc to the system, then use it to
disable any startup items that seem odd.
Use another antivirus program to scan for viruses - AVAST is a nice free
one.
Some infections can only be destroyed manually.
Good Luck,
Charles
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, November 02, 2004 9:24 AM
Subject: [Vantage] OT: Processor crunching away
> I have a Dell Optiplex system. For some reason the processor keeps
> crunching and crunching even when I am away from the system. Can
> someone give me an idea why? I have run AdAware to remove all
> spyware and ran a complete virus scan. What else could be happening
> here? Thanks.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
here? Thanks.
Check to see what process is using up the CPU. Then do a search on yahoo/google for that process to see what it is.
here? Thanks.
Yahoo! Groups Links
What does the performance monitor in the task manager tell you? What does the CPU usage look like?
Jasper
here? Thanks.
Yahoo! Groups Links
We usually back our Adaware scans up by scanning with Spybots. It finds
things the lavasoft program doesn't. Also, found a small program called
CWShredder that ditches the cool web search internet hijacker software (all
this is on www.majorgeeks.com). Also, make sure you have the latest updates
for Adaware and Spybots. It's like they have updates every day or so.
Paul L.
Sent: Tuesday, November 02, 2004 8:24 AM
here? Thanks.
jp
Sent: Tuesday, November 02, 2004 9:27 AM
Subject: RE: [Vantage] OT: Processor crunching away
Jasper
here? Thanks.
Yahoo! Groups Links
Yahoo! Groups Links
Thanks Paul for this information.
Sent: Tuesday, November 02, 2004 8:31 AM
Paul L.
here? Thanks.
Yahoo! Groups Links
Lois
You should also run Spybot S & D and CWShredder.
None of the Anti-Spy software catches everything.
More importantly they don't necessarily fix everything either.
You should also look into a program called Hijackthis as another tool.
If you think it is a spyware problem and none of the above help and you
can't Google a solution
Reformat your hard disk reload the OS from a CD starting from power off.
If you just put the CD in and reformat etc., while the PC is running it
may not cure the problem.
I have a PC here that was infected just this way and nothing would
remove the Spyware.
Lastly if possible stop running MS Internet Explorer
Go get the Mozilla browser or the newer version called Firebird.
They both are better at blocking pop ups, natively, that most pop up
blockers I have seen.
They seem to be more secure than IE.
Maybe someone with more info can expand on the browser issue.
Regards
Rich
> here? Thanks.
REBOOT!
Sent: Tuesday, November 02, 2004 9:55 AM
Subject: Re: [Vantage] OT: Processor crunching away
Lois
remove the Spyware.
Regards
Rich
> here? Thanks.
Yahoo! Groups Links
