OT - Server 2003 , Registering 6GB Memory
Thanks for all the replies.
--- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@...> wrote:
> You need enterprise of Windows Server 2003 (32 Bit) to access any
more
> than the Maximum 4GB from Windows.
> The hardware may have a larger Memory limit, may successfully
detect it,
> but windows 2003 Standard enforces the 4GB
> R2 comes in both versions. (Standard and Enterprise), but has no
effect
> on Memory limits in the Standard version (Still 4GB)
> In the Enterprise Edition (32 Bit) has a 32GB Limit, R2 increases
this
> edition to 64GB
> The 4GB of RAM accessed by Windows 2003 Standard inc R2 is split
into
> two halves of 2GB (Kernel and User Mode)
> It is possible to change this to a 1GB to 3GB ratio, meaning
> applications can utilize 3GB's of the 4GB
> This is done by adding the "/3GB" to the boot.ini file of Windows
in the
> root of the C drive, but please bear in mind the applications you
are
> running must support this.
> Regards
> Gary Parfrey
Behalf
> Of Gary Franks
> Sent: 05 July 2006 21:30
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: OT - Server 2003 , Registering 6GB Memory
> Almost forgot....If you're running server 2003 Std, then it won't
see
> past 4GB, unfortunately. You need Enterprise or R2 to see the
> additional.
> - Gary -
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "brychanwilliams" <brychanw@> wrote:
> > Hi,
> > We have installed 6Gb into a server but 2003 is only seeing 4gb.
How
> > do I go about windows seeing the full 6Gb. It is a HP server.
> > Thanks in advance.
> This e-mail is for the use of the intended recipient(s) only. If
you have received this e-mail in error, please notify the sender
immediately and then delete it. If you are not the intended
recipient, you must not use, disclose or distribute this e-mail
without the author's prior permission. We have taken precautions to
minimize the risk of transmitting software viruses, but we advise
you to carry out your own virus checks on any attachment to this
message. We cannot accept liability for any loss or damage caused by
software viruses.
Hi,
We have installed 6Gb into a server but 2003 is only seeing 4gb. How
Thanks in advance.
Hi Brychan
Are you running Standard or Enterprise?
I think Standard only supports upto 4GB
Gary
Of brychanwilliams
Sent: 03 July 2006 10:10
Subject: [Vantage] OT - Server 2003 , Registering 6GB Memory
Hi,
Thanks in advance.
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
Hi Gary,
It is enterprise, so I am a bit perplexed.
> Hi Brychan
> Gary
Behalf
> Of brychanwilliams
> Hi,
How
> Thanks in advance.
software viruses.
Sorry, the IT guy just checked and it is standard, thanks gary.
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@...>
wrote:
> Hi Gary,
> --- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@> wrote:
> > Hi Brychan
> > Gary
On
> Behalf
> > Of brychanwilliams
> > Hi,
> How
> > Thanks in advance.
to
by
> software viruses.
Hi Gary,
Would you know how much it costs to upgrade?
> Hi Brychan
> Gary
Behalf
> Of brychanwilliams
> Hi,
How
> Thanks in advance.
software viruses.
use the 3GB switch in the boot.ini
Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
brychanwilliams
Sent: Monday, July 03, 2006 8:01 AM
Hi Gary,
--- In HYPERLINK "mailto:vantage%40yahoogroups.com"vantage@...,
> Hi Brychan
> Gary
> ____________-_________-_________-__
> From: HYPERLINK "mailto:vantage%40yahoogroups.com"vantage@...
[mailto: HYPERLINK
"mailto:vantage%40yahoogroups.com"vantage@...] On
Behalf
> Of brychanwilliams
> To: HYPERLINK "mailto:vantage%40yahoogroups.com"vantage@...
> Hi,
How
> Thanks in advance.
software viruses.
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.8/380 - Release Date: 6/30/2006
No virus found in this outgoing message.
We paid approximately 2,200 for the Enterprise Edicion.
_____
Of brychanwilliams
Sent: Monday, July 03, 2006 7:01 AM
Hi Gary,
> Hi Brychan
> Gary
Behalf
> Of brychanwilliams
> Hi,
How
> Thanks in advance.
software viruses.
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@...> wrote:
> Hi,
> Thanks in advance.
Windows 2003 Server Standard Version has a limit of 4gb. As far as
I'm aware the only way to increase this limit, in Windows, is buy the
Enterprise version of 2003 which, I think, goes up to 12gb.
Martin Horton
Group IT Manager
PRD Holdings Ltd.
If this is an HP version of a Compaq server, just installing the
additional memory isn't enough...You also need to go into the BIOS
setup (if you see a blinking rectangle in the upper right when you
first boot the server, hit F10 to get there) and use the utilities
found there to discover the hardware changes. Once the server
recognizes the additional memory at the BIOS level, Windows will
follow just fine....except for the pagefile setting. You should also
delete and recreate the pagefile setting to match the memory
complement, for the most efficient processing.
Hope that helps.......Gary
> Hi,
> Thanks in advance.
Correct.....Microsoft stopped offering upgrades to anything except the
workstation version of Windows. For Server, you would need to either
install Enterprise on top of what you have, or install R2, which uses
more memory.
- Gary -
--- In vantage@yahoogroups.com, "marthorton2000" <martinh@...> wrote:
> --- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@> wrote:
> > Hi,
> > Thanks in advance.
> Martin Horton
> Group IT Manager
> PRD Holdings Ltd.
Almost forgot....If you're running server 2003 Std, then it won't see
past 4GB, unfortunately. You need Enterprise or R2 to see the additional.
- Gary -
> Hi,
> Thanks in advance.
You need enterprise of Windows Server 2003 (32 Bit) to access any more
The hardware may have a larger Memory limit, may successfully detect it,
R2 comes in both versions. (Standard and Enterprise), but has no effect
In the Enterprise Edition (32 Bit) has a 32GB Limit, R2 increases this
edition to 64GB
The 4GB of RAM accessed by Windows 2003 Standard inc R2 is split into
This is done by adding the "/3GB" to the boot.ini file of Windows in the
root of the C drive, but please bear in mind the applications you are
Regards
Gary Parfrey
Of Gary Franks
additional.
- Gary -
> Hi,
> Thanks in advance.
Anyone using Windows 2003 Server x64 for Vantage Server or Windows XP Professional x64 on the client? How do they compare on performance to non-x64 versions?
----- Original Message -----
Sent: Wednesday, July 05, 2006 2:28 PM
Subject: RE: [Vantage] Re: OT - Server 2003 , Registering 6GB Memory
edition to 64GB
Regards
Gary Parfrey
Of Gary Franks
additional.
- Gary -
> Hi,
> Thanks in advance.
